DIY Standard Coffee Table
2,568
47
Published
Introduction: DIY Standard Coffee Table
WARNING: Use with caution! Electric tools used in the construction of the coffee table.
Materials Needed:
1 Sheet of Plywood: (48” X 24”)
1 Pallet: (42”X 42”)
Tools:
#305 Stainless Steel 3 inch x 10 Screws
Electric Saw
Power Drill with variable sized Drill bits
Measuring Tape
Hammer
Crow bar
Clamp (Optional)
Step 1: Preparations
Disassembling the Pallet to achieve Pallet wood strips.
You will need: Hammer, Electric Saw & Crow bar
Step 2: Building the Frame
Dimensions: Pallet length is measured to 42 inches.
a. Measure & cut frame wood pieces
You will need: 3 pieces of pallet wood, electric saw, screws & measuring tape.
  • Cut one of the three strips of wood in half. (18 inches)
b. Attach the frame pieces
  • Using your tools listed above attach the four pieces of wood at their ends; forming a rectangle shape for your frame.
Step 3: Creating the Legs
You will need: Two, 42" x 2" x 4" wood pallet strips (preferable choose thickest strips). Cut each strip of pallet in half, resulting in four legs for the table.
Dimension of legs: Four legs, 18" x 4"
Step 4: Pre-drill & Attach
a. Pre-drill 3 holes at the end of pallet strip.
  • IMPORTANT: Pallet wood is hard, so once the actual pre-drilling with the screws are executed, applying the now pre-drilled pallets into the frame eliminates breakage.
You will need: Power Drill
b. Attach the legs to the frame
You will need: Power drill & 3-4 Screws
c. Stabilize the legs
  • Total of 1-2 screws
Step 5: Attaching Top Shelf to Frame
You will need: Power drill and 4 screws, and plywood (48" x 24").
  • Inspect alignment of frame to top shelf at to your desire, then view finished product.
  • Place the plywood on top of the frame and drill 1 screw from the top of the plywood into the frame.
Step 6: Final Product
Ta-da!
Optional: Staining for color-balanced finish
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    3 Comments
    Awesome project! I need to post my projects on here. I love working with pallets not because of them being free but I like re-purposing and the marks and nail holes add to the character!
