Introduction: DIY Star Wars TIE Fighter Bookshelf
Picture of DIY Star Wars TIE Fighter Bookshelf
Hi, I'm Ashley. I'm a long time lurker and this is my very first Instructable!
Since the release of The Force Awakens, whenever I brainstorm new project ideas a Star Wars related idea always comes up! Today’s project just so happens to be another Star Wars themed project; it’s a TIE fighter bookshelf! I was able to make use of some scrap lumber I already owned. Paint was the only item I purchased for the project. Everything else I had on hand. Follow along and build one for yourself or the Star Wars fan in your life.
WHAT YOU WILL NEED:
  • Circular saw
  • Jigsaw
  • Kreg Jig
  • Ruler / straight edge
  • clamps
  • Orbital sander
  • Lumber
    • 3/4" thick plywood - 13" x 26"
    • 1x8 board - 48"
  • Gray paint
  • Black paint
  • 1" thick painter's tape
  • 1/2" thick washi tape (I used this as painter's tape)
  • Wood glue
  • Wood filler
  • Screws
I originally shared this project on my DIY blog, Handmade with Ashley.
If you enjoyed this Instructable, please vote for it in the Woodworking Contest! :)
Step 1: Cut the Wood to the Appropriate Sizes
Picture of Cut the Wood to the Appropriate Sizes
Cut the sheet of plywood down into two 13" squares.
Cut the 1x8 board into two pieces 24" long.
Step 2: Cut Out the TIE Fighter Wing Shape
Picture of Cut Out the TIE Fighter Wing Shape
The TIE figher wings are shaped sorta like a hexagon. Use a jigsaw to cut out the shape.
  1. Draw a line from the midpoint of each side
  2. Mearsure 2" from the corner and create a line from that point to the midpoint.
  3. Cut along the diagonal lines
Step 3: Drill Pocket Holes
Picture of Drill Pocket Holes
Create pocket hole joints to join the boards.
  1. Create 3 pocket holes on the long side of one of the 1x8 boards
  2. Create 2 pocket holes on the each short side of the 1x8 boards
Step 4: Paint the Bookshelf
Picture of Paint the Bookshelf
Prep the surface of the lumber for painting. (You can assemble the shelf before painting. I painted half, then assembled the shelf and then painted the remaining half.)
First coat the shelf with a base of gray paint.
Once the base coat is dried, paint the TIE figher wings:
  1. Tape of border of the wing with 1" painter's tape
  2. Use tape to connect the opposing corners
  3. Use tape to create a small hexagon shape at the intersection of all the tape lines
  4. Paint the exposed area with black paint
While the wings are drying, paint the TIE fighter cockpit:
  1. Draw the shape of a semi-circle in the center of the 1x8 boards (If you are painting the shelf before assembling be sure to take that into account when you draw the semi-circles)
  2. Draw the shape of an octagon in the center of the joined semi-circles
  3. With 1/2" painter's tape (I used washi tape because I could not find painter's tape that thin), mask off from each point on the octagon to the outer circle (see picture).
Step 5: Assemble the Bookshelf
Picture of Assemble the Bookshelf
Join the 1x8 boards at 90 degrees. Attach the shelf to each wing.
Step 6: Seal the Project and Enjoy
Picture of Seal the Project and Enjoy
Finally coat the shelf with your favorite sealer and start filling it up with books!
Mjtrinihobby (author)2016-12-26
Amazing work.
AnılY17 (author)2016-08-01
ıts very creative thans for sharing
http://ecemiselbiseleri.com/
Riffifi (author)2016-07-28
on a slightly bigger scale, it becomes a bench :D
Jedi_zombie85 (author)Riffifi2016-08-01
beat me to this idea lol
Natalina (author)2016-07-29
Great idea! The fighter works so well in this form. And doubles as a toddler bench :)
craftvideos (author)2016-07-28
Wow this is simply awesome. So stylish and so easy to make. BIG THANK YOU
I need some encouragement from creative people like you. Please visit my instructables and say few words -https://www.instructables.com/member/craftvideos?show=INSTRUCTABLES
thanks! :)
wold630 (author)2016-07-28
This is just fabulous and so creative!
thank you! :)
BKLaRue (author)2016-07-28
Totally awesome!!! Great work! Voted...
thank you very much! :)
Hiroak (author)2016-07-28
Great job I'm going to make one like this as a bench. I also went to your website, you do fine work indeed, keep it up.
thank you! :) Share a picture when you finish it. I'd love to see how it turns it out. :)
MissionSRX (author)2016-07-28
Nicely done! A strong start and welcome to the party! (we'll be watching your career with great interest)
About This Instructable
4,860views
168favorites
License:
Bio: Hi, I am Ashley. I am a geek and woodworker. I am author of the DIY and woodworking blog, Handmade with Ashley. I also have ... More »
More by handmadewithashley:How to Make a Giant Pixel MarioHow to Make a Tardis End Grain Cutting BoardDIY BB-8 Push Toy Tutorial
Add instructable to:
