DIY Stirrer/Hot Plate by amaloney
All research areas, be it physics or chemistry or biology, will require at some point in time a stirrer and or a hot plate or a stirrer hot plate combo. These things are quite expensive even when they are barebones devices. If you want one that has PID temperature control, than tack on an extra order of magnitude to the cost of the barebones device if it is sourced from a scientific supply company.
DIYBio has become a big thing lately. Especially with builds like the Pearl Gel Box which literally costs a fraction of what a "scientific" labeled unit would cost. Having access to cheap and easily assembled devices to do garage science really does enhance the whole science community in my opinion. One reason why I think garage science is a good thing is that most people in the hacker space that do garage science like to communicate about what they have done, hence the need for a site like Instructables. Open communication is crucial for science to progress as I am a firm believer that progress is dictated by communication. And, if progress is to succeed, communication must be open. So, thanks to all those that participate in tinkering and are willing to share those endeavors. Scientists could learn something from the community at Instructables.
This build is cheap, easy and voids lots of warranties. With that said, do be careful with this build.
The video of this in action is not embedding properly so a link to it is here.
http://www.youtube.com/watch?v=YKWimlx2_44
Update 02-02-2011: Attempting to embed the video again. If you can't see it, use the link above.
Step 1: Tools and materials
Materials
1x Modified Computer Power Supply
1x Electric Griddle
1x Computer Fan  - Hopefully salvaged from the same computer you got the power supply from.
1x DC Motor Controller
1x Rare Earth Magnets
1x Stir Bar
Beakers and the like to do your science in.
2x Banana plugs - Any color. I'm partial to the Emerson / Johnson brand.
4x Banana jacks - Any color. Again, I like the Emerson / Johnson brand.
4x Spacers
4x 4-40 Screws
2x Banana Cables - Any color.
1x Epoxy
1x Solder
Tools
1x Soldering Iron
1x Wire Stripper
1x Diagonal Cutters
1x #1 Phillips Head Screwdriver
sniperHunted says: Aug 10, 2011. 9:06 PM
what if you just needed the hot plate?
amaloney (author) says: Sep 15, 2011. 6:22 PM
if you didn't want to use the stirring action, then you don't have to turn the fan on under the plate.
alexg50 says: Feb 23, 2011. 1:06 PM
the third wire is for the temperature sensor, with a common ground with the fan
FrozenFire says: Mar 20, 2011. 3:13 AM
What third wire, if I may ask? Fans don't have a temperature sensor - three-wire fans *do* have a rotation sensor on the third pin. It requires a pullup though.
amaloney (author) says: Feb 23, 2011. 2:06 PM
Ha! That's awesome! I never knew that. Thanks ever so much for letting me know. I will definitely use this in the future for other projects.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
