loading
Step 4: Make the String
you now need to braid the string. this is a tedious process that will take a while to do, but if done well, will make a string that will last years to come. After that knot the string so it makes a place for the notch to hold onto.
What is the draw weight?
I don't remember, but it was really light, 30 lbs at most, depending on the length of your bow and string
How long should the bow be unstringed for someone that is 6'2" and has a 38" draw length
<p>Hilarious and sad you have to add the caveat regarding 'if you kill yourself... I'm not responsible'. Signs of our times!</p>
<p>Do you use standard arrows with this? How long would you make the bow for a person 5'3&quot;?</p>
<p>I know you used Sch 80 PVC but what size or diameter of PVC did you use for this project, 3/8&quot;, 1/2&quot; 1&quot; ???</p>
<p>Wow.... people still use this instructable. Anyway onto your question. i used Schedule 80, 1/2&quot; Inner diameter PVC pipe. Thanks for looking!</p>
I love this idea and want to try it this weekend. I have 3 questions; what size string did you use to make the braid? What did you use to make the ledge? Could you go into more detail about the knot so you can string the bow? <br> <br>Thanks!!
1. I used some nylon string guesstimating....... about 1-2 mm thick. you could go the easy route and use just strait 550 para-cord. <br>2. I used some plastic off of something. you could just use a small piece of wood and duct tape and electrical tape it on like I did LOL! <br>3.I used a simple knot-with-in-a-knot method, double knot, what ever you want to call it. i doesnt matter what knot it is as long as it wont slip! <br> <br>just remember to make your notches deep enough and thin enough that the string wont slip out and sping you in the head! <br>And use Schedule 80 ONLY!! <br>Its cool that someone is still using this instructable. <br>thanks for your question!
About This Instructable
91,005views
82favorites
License:
Bio: Im a 13 year old kid that likes to take stuff apart and repurpose things. and even build my own stuff too!
More by newwarhammer2:DIY Survival PVC Bow Make A Backlay For Any Clock! Make a USB breadboard power supply for close to nothing!
Add instructable to:
