This year's Christmas ornament gift is different for each Thing. We're all about Dr. Who these days, so Thing One wanted a TARDIS, and Thing Two wanted a Dalek, which is on here as a separate instructable. It's probably the last year I'll do different ones, but wanted to accommodate wishes and mix things up a little. The good news is that both Things are thrilled with their respective ornaments.
I do write a message, the year, and Thing name on each year's ornament. I do it at the end, after all pics are taken - so they will (and already do) each have a great collection of one-of-a-kind ornaments. Maybe they will carry on the tradition with their kids...
They were a lot of fun to make, and it's always nice to make something out of 100% recycled stuff - I didn't buy anything for these ornaments, all materials were scavenged/re-purposed from around the house or leftovers from Modfrugal's various projects.
This was also the first year that the ornaments glow...the LEDs added a nice touch.
So - read on for a how-to on the Time And Relative Dimension In Space...
Ingredients:
Thin ply-wood for the walls, floor and roof - I used an old fruit box
Craft Paint and Sharpie pens
Wood glue or White glue
Epoxy glue (you could use a glue gun...it's just that I'm an epoxy man)
Label paper for the sign stickers
A small hinge
plastic pen
LED tealight plus a small LED white light
Assorted tools (pliars, wire cutter, screwdriver, box cutter etc.)
small eye hook (to make this thing an ornament)
Step 1: Cut the Walls, floor & Roof
We had a few old grocery boxes, and I thought the thin plywood was perfect construction material. Think this housed tangerines or somesuch.
1. Remove the heavy duty staples holding the box together.
2. You should have plenty of undamaged materials for the walls, floor and roof of the TARDIS.
Step 2: Cut Paint Print Assemble
1.  Draw a Template of the sides, floor, and roof. One of the side templates will be wider than the other, as two sides will be .25" wider to account for the thickness of the material at the corners. Google TARDIS and there are plenty of images to inspire your design.
          There are 4x2 square door panels on the TARDIS, with the top ones each being a window with 3x2 panes
          I went with the existing dimensions from the fruit box, so the height was 3.5".
          It worked out nicely that the door panels were 0.5" square
          Panel frames were 1/8" wide, and 1/4" to the edge.
          Which left just the right amount of room at the bottom and top, including the space for the 'POLICE BOX' sign.
2. Cut out all the door panels on the main template using a sharp knife. We will use this to draw the panels with a Sharpie onto the doors after they have been painted.
3. Using the templates, mark the wood and cut out the shapes using cutting medium of your choice. I used a mitre chop saw. Exercise extreme caution and play safely.
4. Position the template on the wood and draw the top two panels on each side which will be the windows. Then cut out the panels - I used a 1/2" wood chisel which worked perfectly.
5. Cut out the window material: I used some strips of a translucent vellum paper that we had left over from something. You could use plastic packaging that's been lightly sanded, or probably white plain paper would be just fine.
6. The roof has two pieces that will be glued together before you paint all the pieces. I then mixed up an approximation of 'TARDIS Blue' using bright blue, black, and grey. Paint all pieces.
7. Glue the windows on the inside back of each side, and then draw the panes - I used a thin black Sharpie. There are 6 panes on the TARDIS, so one horizontal line and a couple of verticals. I drew lines on both sides of the paper.
8. Now draw the rest of the door panels using sharpies. I used a light blue for the bottom/left sides of the square, and black for the top/right sides. You can't see it too well in the pics, but  it makes it look like the panels are recessed. I copied this effect from mradau's rocking TARDIS bedroom door. Thanks for the inspiration.
Step 3: Signage
The signage was done in Word and printed out onto label paper. Completely unnecessary, but I wanted to see if I could print the actual door sign onto a 0.4 square to fit onto the 0.5" door panel. Turns out this can indeed be done, and young naked eyes can actually read it.
Front Door Sign (text box size 0.4" square):
POLICE TELEPHONE (Times New Roman 2)
FREE (Times New Roman 3)
FOR USE OF (Times New Roman 2)
PUBLIC (Times New Roman 3)
ADVICE AND ASSISTANCE OBTAINABLE IMMEDIATELY
OFFICER AND CARS
RESPOND TO ALL CALLS (Verdana 2)
PULL TO OPEN (Verdana 3)
Police Box Signs (table: 1 row 3 columns, table width 1.75"):
 POLICE (Verdana 13) PUBLIC CALL (Verdana 6) BOX (Verdana 13)
White type, black fill.
Make one and then copy it a bunch of times. Then cut out the labels and stick 'em to the TARDIS wall panels. I found that the tip of an exacto knife helps with picking the inital separation from the backing, these things are too small and fiddley for my fingers.
The black background comes off pretty easily when touched, so handle with care while applying to the TARDIS walls - it will fade with repeat handling until you can seal it with varnish.
Step 4: The Roof and Glue the TARDIS together
The TARDIS has a white/blue light at the top which lights when it travels through time I think...so this is where the LED shall be. I decided to glue a modified tealight to the inside of the roof, and have the LED poke into the inside of a plastic pen top that you can then see emitting from the roof.
I figured the easiest way to access the tealight switch was to have the roof be a hinged lid. Thing one wanted the box to have an additional yellow tealight inside, to give a yellow glow through the windows, otherwise I would have considered having the LED in the bottom with longer wires connecting to the LED up top. This would have cluttered the inside with wires though. Plus, I had some small decorative hinges, and one of them was the perfect size.
1. Attach one side of the hinge to a wall panel. I did use the little nails and clipped off the excess on the inside, but didn't need to, as the epoxy glue was rock solid on its own.
2. Hold up the roof in place, mark and cut out a notch to accommodate the hinge rib. Don't attach the hinge to the roof yet.
3.Find an old plastic pen, and cut off the end tip. Pen needs to be clear or translucent so the LED will shine on through.
4. Draw an X across the roof top to find the center, and drill a hole the same diameter as the pen top. Glue the pen top into the hole with epoxy.
5. Screw a tiny eye screw into the top of the pen top - this is where the ornament will hang.
6. Now glue the walls together with wood glue. I used rubber bands to hold it together while it dried. Careful though...lack of precision can crumble that setup in an instant. Also glue on the base - this will give some much needed stability.
7. When the TARDIS body is dry and solid, line up and glue on the roof with epoxy. Glue it with the lid open to allow a full range of movement.
8. Now is probably a good time to seal/varnish/poly the whole exterior.
Step 5: The Rooftop LED
This was a fun part. As with the Dalek ornament, I decided to hack/ recycle some inexpensive lights we already had. The tealight body would be great, as it has a nice push-button switch on the bottom and could be glued to the inside of the hinged roof. The tealight LED was flickering yellow, so I needed to swap it for a white one. We had white ones in another cheap LED thingy from Halloween. Both had the same voltage batteries, so I figured it would work.
1. Cut out the top of the tealight, carefully.
2. Heat up the ol' solder iron and remove the yellow bulb. Just the LED - leave the wires on.
3.Open up the other small white LED and remove the bulb. Luckily this one was not soldered. Score.
4. Solder the ends of the white LED bulb to the two wires on the tealight. They only work one way around, so make sure it lights before soldering! In mine, the short leg connected to the wire going through the switch.
5. Push the LED through and into the pen top in the roof, then glue the tealight base to the roof with epoxy. Check your clearance first - I had to remove some height, cutting off about 1/4" all around the base. Otherwise the tealight will catch on the front wall of the TARDIS when you try to close it.
6. Glue a magnet to an inside corner with epoxy, and a thin washer to the roof - this will keep the lid closed when it needs to be. My washer wasn't positioned well, and the roof doesn't close completely....maybe a fix down the road. Even though it bugs my perfectionist self - this is just an ornament.
1-40 of 41Next »
StoryAddict says: Jan 7, 2013. 9:57 AM
One of our favorite ornaments is a Hallmark Darth Vader that plays a famous line when we turn the lights on or press a button. You just need to rig your Tardis to play the Whovian theme and you're golden!
Peale in reply to StoryAddictJan 21, 2013. 12:49 PM
I'm working on that. I'm starting off with the light that fades, in and out, but ultimately I want it to make the TARDIS sound. I /think/ I can get an Arduino to do it, it just depends on the amount of space I can cram the code into it.
Crimson-Deity in reply to PealeApr 3, 2013. 2:36 PM
Arduino Wave Shield.
sabu.dawdy says: Jan 21, 2013. 7:44 AM
i just loveddd ur ideaaa
jimmysymo says: Dec 31, 2012. 4:40 AM
Yes a good Christmas present,for the kido.and your perfection ig great.(smile)
Peale says: Dec 17, 2012. 7:59 AM
The tealight on the top - does it flicker?
It would be really cool to have a light that fades in and out. I wonder if there's an off-the-shelf solution.
lburch1 in reply to PealeDec 25, 2012. 9:48 AM
With an http://www.arduino.cc you could. I would suggest an Arduino Nano. See http://www.arduino.cc/en/Tutorial/DimmingLEDs for a code example.
Peale in reply to lburch1Dec 27, 2012. 11:22 PM
Oooh...just found this: http://www.youtube.com/watch?NR=1&feature=endscreen&v=30rPt802n1k
But, of course, I don't have an Arduino to program one of these chips. Oh, well.
Peale in reply to lburch1Dec 27, 2012. 7:22 AM
That particular example could especially work for the Dalek ornament, since there are three LEDs.
Peale in reply to lburch1Dec 27, 2012. 7:21 AM
Ah, yes, that would work. I'd want to program just a chip to handle that function, rather than use an entire Arduino for that.
http://www.instructables.com/id/The-RRRRRRRRRRBA-or-What-They-Dont-Teach-You-in-/
craftycounterpart (author) in reply to PealeDec 17, 2012. 8:48 AM
Yeah that would be cool...there probably is one out there, or the techies on here could show how to wire one up?
lburch1 says: Dec 16, 2012. 10:49 PM
It references a English SiFi TV show "Dr Who".
wolfkit in reply to lburch1Dec 24, 2012. 11:47 PM
'Doctor Who' actually.
sibu says: Dec 17, 2012. 9:52 AM
Pantone 2955C is called Tardis blue if you don't want to mix your own paint.
craftycounterpart (author) in reply to sibuDec 17, 2012. 11:06 AM
Ha - awesome!!
sibu says: Dec 17, 2012. 10:04 AM
Well done!
Nirgal38 says: Dec 16, 2012. 9:29 AM
I have every intention of making one of these for my Whovian family!
craftycounterpart (author) in reply to Nirgal38Dec 17, 2012. 8:49 AM
Please post a pic when you do!
ynneb says: Dec 16, 2012. 1:49 PM
Mine didn't work. It made the woo woo noise, but didn't disappear.
craftycounterpart (author) in reply to ynnebDec 17, 2012. 8:45 AM
You must have missed the elf magic step.
HowardC says: Dec 16, 2012. 7:58 AM
Fantastic idea! I have some suggestions for improvement on the build though in case you want to do more.
1. I wouldn't use wood. It's certainly sturdier, but heavy ornaments and Christmas trees don't always mix well. I would suggest using the foam project board we all used in elementary school. It's not as sturdy, but it wouldn't be any more fragile than your typical glass ornament. You can get it in different colors as well, so you might be able to skip the painting step!
2. We have a few commercial ornaments on our tree that are lighted. Instead of using a power source, what they do is use a length of wire with a christmas bulb connector coming out of the back. So once you put it on the tree you simply unplug one of the bulbs and plug the ornament in. Now obviously if you are using led lights on your tree you have to use leds in the ornament and incandescent if otherwise. It does save you from having to deal with batteries, and switches, and a cumbersome top-hinge though. If you don't want to do it that way, I would make a hole in the bottom of the tardis indstead.. the size of the tea candle base. Then you can glue it in place flush with the bottom, paint the base blue and you have access to the battery and switch.
3. They actually sell blinking and fading leds on ebay these days for next to nothing. It would be a lot cooler if it pulsed. ;)
craftycounterpart (author) in reply to HowardCDec 17, 2012. 8:43 AM
Thanks...like the improvement ideas! The wood isn't actually that heavy, and we have plenty of heavier ornaments so it's not a big deal for us - but yes, lighter is better in general for any ornament. Agree that the light in the base would be more accessable (that's what I did for the Dalek), and also blinking/fading LEDs would be a good enhancement, if you have them. Would love to see pics of others improvements...it can only get better :)
dantistus says: Dec 16, 2012. 6:49 AM
Nice! Are you planning to make an instructable about the awesome Dalek? :)
craftycounterpart (author) in reply to dantistusDec 17, 2012. 8:39 AM
Thanks...yes it's on here: http://www.instructables.com/id/DIY-Dalek-Ornament/
ladykila says: Dec 17, 2012. 5:06 AM
http://www.ebay.com/itm/fit-Gamewell-POLICE-Alarm-Call-box-CAGED-LIGHT-Blue-Bulb-Clear-Lens-Emergency-/181046689829?pt=LH_DefaultDomain_0&hash=item2a27394025
Has a light for sale but it also has instructions on how to buy and build your own.
Dusk Shadows says: Dec 16, 2012. 5:28 PM
AWESOME!
kevinhannan says: Dec 16, 2012. 6:24 AM
I've been planning on a tardis-shed for the garden. For weeks and months now I have tried to find an enamel sign for the front door and a suitable blue lantern for the top but cannot find any. Any help, please? Many thanks.
zigzagchris in reply to kevinhannanDec 16, 2012. 3:57 PM
I remember reading somewhere the uk had a large number of the red telephone booths in a warehouse they were selling for close to nothing. I cant find the article anymore..
HowardC in reply to kevinhannanDec 16, 2012. 8:08 AM
You won't find a original sign, unless you want to pay a ton for it. Go to kinkos and they should be able to print out a suitable plastic sign. There's also the option of getting one screen-printed on wood/metal, but that will cost ya.
The lantern glass used in the tardis's is very similar if not identical to blue glassed railroad lanterns. Go check out eBay. If that doesn't work they make very similar clear glass domes for porch lights. Go to your local home improvmentand get one that looks close. After that you can actually paint it. They make translucent paints for faux stained glass windows and model kits. Try either one.... I believe Testers makes some really nice colors for models.
kevinhannan in reply to HowardCDec 17, 2012. 12:22 PM
Thank you all for your time and trouble - I will now go and order one! Many thanks again!
HowardC in reply to HowardCDec 16, 2012. 8:14 AM
Actually, I take that back... you won't find an original sign that looks like any of the ones on the show period. Although the Tardis is based upon a English police box, the Tardi (there were several designs over the years) were all custom built and had custom sinage.
A wooden police box, even way back when Dr. Who was a new show, was quite rare, possibly even non-existant. They were usually made out of cement for durability.
gafisher in reply to HowardCDec 16, 2012. 10:44 AM
The MacKenzie Trench design used for the TARDIS was introduced by the Metropolitan Police in 1929 and finally phased out around 1970, so for the first seven years of the show, the real thing was both familiar and accessible. These were designed from the beginning (1929) to be constructed of cement except for a teak door. Great suggestion regarding the signage -- Kinko's or any local sign shop can make one just as good as the prop originals.
M.C. Langer says: Dec 16, 2012. 3:50 PM
Amazing job! TARDIS ornaments are cool!! :-)
kouellette says: Dec 16, 2012. 12:00 PM
This is great for a FB friend...Dark Atlantis, I know she'd love anything from Doctor Who..!
Dark if you see me post this check it out maybe you want to build it for yourself! <3
gafisher says: Dec 16, 2012. 10:49 AM
VERY nicely done, and a great use of recycled and re-purposed materials!
tn. says: Dec 16, 2012. 9:05 AM
fabulous!!!!
FuzzyBearGeek says: Dec 16, 2012. 8:46 AM
Very nice.
You are awesome!
Jmae says: Dec 14, 2012. 4:29 AM
Voted! This is awesome! I love the Dalek one as well. Great job!
oldmicah says: Dec 12, 2012. 1:58 PM
That is very cool. Thank you for sharing!
emilyvanleemput says: Dec 12, 2012. 11:36 AM
AWESOME!!!!!!!!!!
btw do the Things relate to dr. Seus?!?!
1-40 of 41Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
