Introduction: DIY Three Strand Blue Beaded Pearl Necklace
Multi-strand necklaces are always in style for all seasons and occasions. With basic beading techniques, you can DIY your own three strand beaded necklace to perfectly match your favorite sundress or shirt. So never miss the tutorial below! And check more free jewelry tutorials at: Pandahall Learning Center
Step 1: You'll Need:
4mm White Pearl Beads
Blue Electroplate Glass Beads
Acrylic Rhinestone Cabochons
Transparent Acrylic Faceted Drop Beads
Faceted Round Glass Beads
Iron Bead Tips
Silver Iron Headpins
Silver Lobster Clasp
Iron Cross Chains
0.3mm Tiger Tail
Diagonal Plier
Round Nose Plier
Diagonal Plier
Stainless-Steel Scissor
Step 2: Make Upper Part of the Necklace
1st, choose an acrylic rhinestone cabochon and cut three strands tiger tail. Then, combine the rhinestone cabochon with the three strands of tiger wire in sequence (as shown in the picture);
2nd, string white pearl beads on the two sides of the inner strand tiger tail and the middle strand tiger tail respectively. Then, string blue electroplate glass beads and white pearl beads in sequence on the two sides of the external strand tiger tail (shown in picture ).
Step 3: Make the Middle Part of the Necklace
1st, string six white pearl beads on the two sides of the tiger wire respectively;
2nd, combine an acrylic rhinestone cabochon with the tiger wire;
3rd, repeat the two steps above;
4th, continue to string white pearl beads. Then, make a loop and cross the tiger wire.
Step 4: Add Transparent Acrylic Faceted Drop Bead
1st, combine the transparent acrylic faceted drop bead with a silver iron headpin. Then, string a white pearl bead above the drop bead;
2nd, make a loop on top of the headpin. Then, cross the tiger wire through the loop to combine the necklace and the drop bead together;
3rd, string white pearl beads and blue electroplate glass beads in sequence on the two sides respectively. Then, make a loop and wrap the tiger wire through the top acrylic rhinestone cabochon.
Step 5: Connect the Two Parts of the Necklace Together
1st, string two or three faceted round glass beads on the two sides of the necklace;
2nd, make a small loop on the left side of the necklace and cut the excess tiger wire on the left side. Then, combine the tiger wire on the right side with an iron bead tip;
3rd, add a silver lobster clasp to connect the two sides together.
Step 6: And Volia! You Have the Big Beaded Necklace Ready!
Step 7:
Sourced from Pandahall Learning center
