Remove these ads by
Signing UpStep 1: The Electronics
Note that if you etch your own PCB the LED's are mounted as normal thru hole components but the IC's, links and other components are placed on the copper side of the board. The LED's and links will need to be mounted first as the AVR covers some of the LED solder points. Details in the pictures.
Visit Our Store »
Go Pro Today »
Is this not going to burn out the LEDs and / or the drivers?
JP2 is the programming connector
Although I have experience doing this kind of stuff back in college, I don't recall how generally to power the breadboard or your board in this case. Did you use a battery? Or is it plugged into the wall with some AC to DC converter between?
this is the first time i see this kind of this clock
was it 12:34 then 12:35?
did i read it right?
i will try to make one like it
Building recyclers should have them by the dozen, hey even check the huge bins when they are refurbishing a building, you might get some for free!
My (possible) attempt will be to cut card-stock in lines and wrap in foil, and make a grid... Will be able to fit more LEDS in a smaller space, and it should work the *same*
Very nice clock indeed.
I noticed that you only supply the .bas file in the zip.
To get the HEX file to program into the AVR, you will need the BASCOM (?) compiler to produce the HEX file.
Could you also supply the HEX file for the AVR?
As for the square grids, you prob could use those square led matrixes, sold on eBay or @ Sparkfun.
Thanks,
Stephen
Where do you bought the square reflector?On internet I can't find it :(
As for the cost, its hard to say, some of bits like the reflector I had lying around, along with the transistors and IC's.
You can buy LED's quite cheaply on the likes of E-Bay etc. So I can't really put a dollar figure on it.
P.S. I live in America.
PCB, show me which are TD62034 (look
the data sheet and nothing)
that code can be used to program in any program IC?
please give me the number of IC1.
And sorry about the TD62034, My dyslexia kicked in, the correct part number is TD62304, it has been corrected in the diagram and parts list.
you can find data on it here: http://www.alldatasheet.com/datasheet-pdf/pdf/32264/TOSHIBA/TD62304AF.html
Excuse me can you tell me how do you programme the clock, via usb?
:D
http://www.eplastics.com/Plastic/Lighting_Diffusers
I also like your Christmas countdown ball thing, it's cute
