3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY TiX Clock
DIY TiX Clock
Here's my instructable for a DIY TiX clock.  It is powered by an AVR microcontroller.  The display is made up using a piece of reflector grid you find covering office lights, some smoked perspex, a diffuser and a bunch of LED's.  The Idea came from the Tix clocks you can buy at various places on the web, but nothing beats making it yourself.  It is a talking point in the lounge and once you are used to reading it, you can tell the time in a jiffy.
Step 1The Electronics
The Electronics
The first prototype was made using Vero strip board.  The layout on strip board is fairly straight forward.  The Transistors in the top left are row drivers and the IC's on the right are  transistor arrays that are the column drivers (see circuit diagram at the end of instructable for more info).  This allows me to get a bit more current to the LEDs to make them brighter.  The Transistor array IC's can be replaced with transistors if you like.  You will find circuit diagrams and software at the end of this instructable with which I have included an Eagle PCB layout design as well for a single sided board that combines the controller and display board into one.
Note that if you etch your own PCB the LED's are mounted as normal thru hole components but the IC's, links and other components are placed on the copper side of the board.  The LED's and links will need to be mounted first as the AVR covers some of the LED solder points.  Details in the pictures.
40 comments
Jan 24, 2012. 4:18 AMmofassir says:
can you please tell me what the JP1 in the schematic is, this is my first time making something so i would appreciate the help
Jan 25, 2012. 9:56 AMmofassir says:
thanks, i actually wanted to know how to implement the JP2. for now i have made the connections as specified on the bread board. in place of the JP2 i have simple use the electrically linked vertical column. i hope that will work.
Dec 6, 2011. 2:34 PMpinchharmonic says:
Hi,
Although I have experience doing this kind of stuff back in college, I don't recall how generally to power the breadboard or your board in this case. Did you use a battery? Or is it plugged into the wall with some AC to DC converter between?
Dec 28, 2011. 8:59 PMWakeUpWolfgang says:
You can use both. Find a 5v dc transformer if you want to use the wall or use a battery pack. If I do this I would go with the transformer so I will not have to keep changing batteries but it would also be nice to have batteries for when the power goes out.
Aug 29, 2011. 7:28 AMaessam1 says:
really nice
this is the first time i see this kind of this clock
was it 12:34 then 12:35?
did i read it right?
Dec 29, 2011. 10:46 PMFouzen says:
Hi, I am having trouble finding the TD62304 Darlington Transistor Arrays IC(I live in Singapore). Do you have any other useful alternatives?
Aug 29, 2011. 1:36 PMaessam1 says:
this clock is better than normal digital clocks
i will try to make one like it
Sep 30, 2011. 8:58 PMastroboy907 says:
How big/where can you get reflector? I think this would be awesome to make a big LED sign :)
Nov 5, 2011. 3:13 PMastroboy907 says:
Theyre kinda expensive...
My (possible) attempt will be to cut card-stock in lines and wrap in foil, and make a grid... Will be able to fit more LEDS in a smaller space, and it should work the *same*
Nov 5, 2011. 3:21 PMastroboy907 says:
oh wait misunderstood the prices.... so this would have 1/2 by 1/2 in holes, 3/8 in high? So about 44 holes x 44 holes? I need just 24x10 :)
Sep 14, 2011. 5:43 AMAlberss says:
Hi.
Very nice clock indeed.
I noticed that you only supply the .bas file in the zip.
To get the HEX file to program into the AVR, you will need the BASCOM (?) compiler to produce the HEX file.
Could you also supply the HEX file for the AVR?
As for the square grids, you prob could use those square led matrixes, sold on eBay or @ Sparkfun.
Thanks,
Stephen
Sep 13, 2011. 7:10 AMastroboy907 says:
Great project- ive never seen this type of clock before. I might try to make a clock before the contest ends, it all depends on if my hardware gets here in time, but could I add something to the clock that will function like this?
Sep 14, 2011. 6:43 AMastroboy907 says:
er.. not to yours but to mine- Im thinking of making a 24x10 LED display and adding digital, binary, 24 clocks, etc... so I might add TiX to that- and instead of having the different colored lights, just light up blocks of LEDs :)
Sep 11, 2011. 11:04 AMherehere says:
Could you tell us how much do you spent?
Where do you bought the square reflector?On internet I can't find it :(
Sep 10, 2011. 10:34 PMtyler303047 says:
Where did you get your materials?
P.S. I live in America.
Sep 9, 2011. 8:12 AMtana_173 says:
sorry can you tell me which program to use for
PCB, show me which are TD62034 (look
the data sheet and nothing)
that code can be used to program in any program IC?
please give me the number of IC1.
Sep 9, 2011. 1:55 PMherehere says:
Hi!
Excuse me can you tell me how do you programme the clock, via usb?
Sep 1, 2011. 4:14 PMTreknology says:
I love it. Yes, I would mod it slightly to suit my own taste but, unlike a binary display you don't have to stand there for half an hour explaining to people how to read it.
Sep 5, 2011. 1:56 PMaessam1 says:
LOL
:D
Sep 3, 2011. 9:25 AMmikerosati says:
I would second a parts list, even simply pcb components at least :) - And great job - I've seen TIX clocks for the last few years, and have wondered more than once about making a giant wall version for my office - this may make me do it :)
Sep 2, 2011. 9:30 AMesdad697 says:
Where do you get the square reflector, a diffuser and smoked Perspex window? How are they assembled?
Sep 1, 2011. 6:49 PMatterack833 says:
holy crap thats awsome , when i first saw it i was all like why do you need 3 lights at the first part then i realized that it swiches the patern but the numbers are the same , i dont think i will ever be able to build this but i am verry amazed by it and i want one (i cant solder good or wire up pcb boards also i wouldnt be able to get the chips , good show though take a bow man take a bow
Aug 29, 2011. 10:58 PMfrank26080115 says:
That construction is slick!
I also like your Christmas countdown ball thing, it's cute
Aug 29, 2011. 5:09 PMFeats says:
I can't understand the first part :(
Aug 29, 2011. 1:23 PMcubeberg says:
Very Nice! Could you post a parts list?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:gweeds(Gweeds.net)
self proclaimed geek with more ideas than money
