1) An SLR or a DSLR camera body with interchangeable lens.
2) An oversized lens. Ebay is great resource, you can pick a high quality lens up for around $15.
3) A rubber accordion-like plunger (preferably a black one, to prevent light leaks, but if you can't find one you can use a different color one like me and just spray paint the inside black).
4) Plastic body cap for your camera.
5) Hot glue gun or other adhesive (super glue optional).
6) Drill, dremel tool, or hobby knife to carve out center of body cap.
7) Black electrical tape.
Remove these ads by
Signing UpStep 1
air compression / vacume pushing shutter about and it didnt like it,first shutter would fire one curtain halfway and the other slowly,this problem escilated into.
shutter auto fire on wind and mirror LOCKED up apature lever STUCK out
after 4 HOURS 'FIXING' (top , bottom and front box off)shutter and winder JAMMED apature lever works and iv got to RESOLDER a wire on light meter
(even tho it was a test spair its a shame as light meter still worked)
if anybody has got any tips on the procedure for reassembling said camera that would be ace as i havent figured what was wrong to fix and lever set up on replacing front
Makers to research: Bronica, Contax, Fuji, Mamiya, Hasselblad, Pentax, Rollei. (Careful though, not all lenses by these makers are medium formatted.)
Are you saying that because of the much larger size of the glass, more of the shot will be in focus, as there is less curvature in the glass in the area the sensor will record?
Perhaps I'm the confused one....
a larger format lens (therefore a larger flange distance) helps the focus of the photo to fall inside the camera's range, whether held close to the body (for marco shots) or further away (for landscapes)
that's why nikon f lenses can be used on canon eos using adaptors, but not the other way around
did you account for the location of the focal point on the lens you used? I'm guessing that you aren't able to get anything in focus because of the distance.
Also using the non-opaque yellow plastic might also mess with your white balance, as well as give poor contrast.
I would like to see samples as well.
http://macroreverse.com/2009/08/07/diy-macro-tilt-shift-extension-tube/
Thanks for posting how you did this :)
