Introduction: DIY Toddler Bed
Picture of DIY Toddler Bed
This is a really easy build which only requires simple tools (however power tools will quicken things), the bed is made out of whitewood pine so it can be painted, stained or left untreated.
Parts
  • 1x 9mm plyboard ( 1200 x 610mm | 4ft x 2ft )
  • 3x 18mm pine whitewood ( 140 x 1800 mm | 5.5" x 6ft )
  • 3x 18mm pine whitewood ( 180 x 1800 mm | 7.0" x 6ft )
  • M5 100mm Wood Screws
Tools
  • Mitresaw or mitre block
  • Set Square
  • Tape Measure
  • Pencil
  • Drill
  • Screwdrivers
  • 5mm Drill Bit
  • CounterSink
  • Assorted Sandpaper
Step 1: Step 1: the Frame
Picture of Step 1: the Frame
To make the sides begin by measuring out 1400mm cuts on two pieces of the 180 board, you can use the piece of plyboard's length to do this, cut the boards and put the offcuts to one side (these will form the headboard).
For the top and bottom you will need to measure out two equal cuts of ~646mm on the remaining board, or if lazy just mark a line at using the width of the ply and and 36mm (18mm x 2).
Drill and countersink four holes into each 646mm board at either ends. Lay your piece of ply down and butt up one side and top, using the board to keep things straight. Screw together!
Next repeat the same step with the bottom board, and then again with the final side to form the frame of the bed.
Step 2: Step 2: the Struts
Picture of Step 2: the Struts
Measure out and make 4 cuts of 610mm on the 140mm board to make the struts. Two of the struts are screwed directly to the top and bottom boards of the frame respectfully, the other two are placed equally inside of the frame.
Roughly layout the boards in the frame and drill, countersink and finally screw them onto the frame, for the end pieces it may be easier to lay the frame down on its ends.
Step 3: Step 3: the Feet
Picture of Step 3: the Feet
With the offcuts from step 2, cut 4 equal lengths to the desired height. Attach them to the frame sides but remember that they should not be placed any higher than the struts (otherwise the board will not lay flat in the frame!)
You can now lie the plyboard sheet inside the frame, if everything went right it should slot it with minimal mechanical retention.
Step 4: Step 4: Headboard
Picture of Step 4: Headboard
The headboard is constructed using the offcuts from step 1 and 2, and will not need any further cuts made to them. Lay the two boards on top of each other horizontally and then lay the further two offcuts at either end vertically so there is at least a 40mm overlap at the end. Screw all the boards together and then attach to one end of the frame.
Step 5: Step 5: Finishing
Picture of Step 5: Finishing
You will want to sand every surface and insure that all sharp edges and splinters are removed. Whitewood is quite soft, so running over it with 60git and 120git will suffice.
Finishing is really up to personal taste, I chose 4 levels of sanding and a gloss varnish.
DIY Hacks and How Tos (author)2016-11-26
Nice design. I like how you kept it low to the ground. My kid falls out of bed all the time.
Thanks! That was a concern for me too, but as she gets older I can always remove the feet an add longer ones
Savannahle5 (author)2016-11-27
roughly what was the price for this in usd?
SFS88 (author)Savannahle52016-11-27
I am not familiar with timber prices outside the UK but I purchased all the wood from a local DIY superstore which frankly is not a cheap as a specialist supplier but was convenient at the time, the screws were part of a multipack from poundland. Roughly came to £27.98 ($34.93) inc tax
ClenseYourPallet (author)2016-11-26
Simple and awesome design! Great job
About This Instructable
1,088views
17favorites
License:
More by SFS88:DIY Toddler Bed
Add instructable to:
