3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Touch Sensor
Step 3Input wire
Strip the tip of the wire and embed it into or behind an object or the surface which you want to act as a touch switch. when connected to a conductive metal sheet, or mesh this works really well. When doing multiple switches, it is important to make sure the surfaces are surrounded by ground, so as to protect each distinct touch surface.
You can see how the light turns on and off when my finger touches the wire.
2 comments
Jul 28, 2010. 12:01 PMaltaholic says:
is there any way i would be able to make an on/off latch for the output?
Dec 22, 2010. 9:07 PMlasermaster3531 says:
If you connect both pin 3 and pin 4 to ground it will latch. There Is an 'ible somewhere around the site about building a USB powered proximity detecting led lamp. Just search up touch lamp and you should find it.
Jan 10, 2011. 10:14 AMaltaholic says:
great, thanks a lot. i'll check that out.
Jun 19, 2010. 5:53 PMMANIAC says:
could you wire it so the LED turns on when you touch it??
Jun 22, 2010. 8:49 PMalezito_gdl says:
Looking at the operating voltages, I assume it uses TTL logical levels (0v for a logical "0"-off, and 2.7v to 5v for a logical "1"-on). So, this circuit is basically giving a logical 1 all the time as long as you are not touching the input wire. The easiest solution, (supposing you are using the direct output, in case you are hooking it To to the MAKE board, all you gotta do is to reprogram) is to add a generic logic inverter, such as the 74LS04, though that would represent a lot of wasted space. You could also build a simple inverter using 2 transistors and some resistors. Input signal for the inverter should be the output from the touch sensor circuit. The +5V would be wired to V+. 2N2222 general purpose NPN transistor should do the trick. Those are cheap and easy to get. Hope this answers your questions!. Image @ http://www.play-hookey.com/digital/experiments/images/ttl_inverter_sch.gif
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
32
Author:giladlotan(giladlotan.com)
Work at the FUSE (future of Social Experience) Microsoft Lab in Cambridge, MA. Alumni of the Interactive Telecommunications Program, New York University. Most recent web visualization: http://giladlo...
more »
