3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Touch Sensor
Step 4Connect to a microcontroller
connect to a microcontroller
In this case I used the MAKE controller - connected the output wire from Step 2 (which was an LED there) into the 4th Input pin of the controller board. When touched, the pin goes low, otherwise its state is high.
In this example, I used the NET connect software to create a flash animation that changes its shape according to a user's touch.
Good Luck!
2 comments
Aug 8, 2010. 3:10 PMshakespeare1212 says:
This device works based on the capacitance of your fingers, right? I would not work if you just touched the wire to a wall, or would it?
Jul 2, 2010. 12:17 PMlaraCat says:
can't believe this is the first time I've seen the MAKE controller! very interested in how you set up your output and the software you used. Can you post a link to any info about the NET connect software you used with flash? tx!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
32
Author:giladlotan(giladlotan.com)
Work at the FUSE (future of Social Experience) Microsoft Lab in Cambridge, MA. Alumni of the Interactive Telecommunications Program, New York University. Most recent web visualization: http://giladlo...
more »
