See the horrible but functional video:
Remove these ads by
Signing UpStep 1Steps 1-5
= a standard dishwashing sponge (others might not work as well, I tried).
= a bic pen (or another pen with a somewhat bendy/soft plastic shaft)
= a metal rod (I got mine from a broken umbrella of which there are plenty in nyc)
= a cigarette lighter or maybe matches.
1)
pull off the tip of the pen (unscrew it, yank it, torque it, whatever)
take out its insides so that all you have left is the tube and the tip
2)
using the lighter heat up the end of your metal rod (maybe hold the rod with paper or something so you don't get burnt)
3)
shove the hot tip of your metal rod through the plastic near where the tip goes on.
shove it in so that the metal rod sticks into the area that the pen tip will cover when you put it back on.
4)
put the pen tip back on (it should have a hole instead of an ink thingy at the tip at this point)
5)
shove as big a piece of sponge as you can into the tip. If a lot hangs out, snip it off with scissors.
uses CONDUCTIVE SPONGE (a graphite embedded sponge)
and the filled my pen tip with it, made into same SHAPE as FINGER.
Thank you guys for putting all the ideas into my head.
-anoop
Thanks for the ideas!!
a small plastic bag with a teaspoon of water in a corner, rubberbanded around an old pen. Works great on the the touchpad for my netbook. Turns out, no metal conductor to my hand is necessary. I am using it for drawing graphic novels on the computer.
Thanks to everyone who contributed to the discussion, the stylus allows much more control over the drawings!
here look at my stylus for ipads and iphones+ ipod
it works with my dell inspiron touchpad too
Paid $19.95, free shipping and got a stylus made by ergonomic, they make portable touchpads, but sell stylus' separate. I haven't received it yet, but I'm hoping it will work. They say they will refund $$, if it doesn't work out.
http://www.ergonomictouchpad.com/stylus.php
like showed here:
http://www.instructables.com/id/%242-Mini-graphics-tablet/
