DIY Tripod Under $1
 by Mfmalive
C:\Documents and Settings\61693\Desktop\uvs070704-001.BMP
This instructable will teach you how to make a fantastic tripod under $1 .Using only household items such as flour,you can make a fantastic tripod which is even better that normal tripod,its even portable..try it!
You should watch the video first,it will explain everything.After that,if you want detali explaination,proceed to the next step.
Step 1: What you need to do
C:\Documents and Settings\61693\My Documents\Ulead VideoStudio\10.0\uvs070609-001.BMP
In this step:
1.put the flour in the plastic bag
2.Depending on how big your camera is,put more flour if your cameara is big.
3.Make sure the plastic or surrounding is not wet
4.DO not add water into the flour
5.Use only plain flour in this experiment so that the surface remains smooth
6.Try to use plastic which are soft and easy to crush
To see how the plastic should be tied,proceed to the next step
Syncopator says: Sep 6, 2007. 4:38 PM
What you describe is not a tripod.
A tripod is a three footed/legged support. (Tri = three, pod = foot.)
You have made a variation of the well-known "bean-bag".
mailkd7 in reply to SyncopatorNov 12, 2007. 4:27 PM
Yes, then the iPod would be
i =me , pod=foot
MeFoot!
Nezer in reply to mailkd7Jun 20, 2010. 8:20 PM
hahahahahahahahahahahaa
Syncopator in reply to mailkd7Nov 13, 2007. 11:23 AM
Very witty!
ledzep567 in reply to SyncopatorJan 12, 2008. 4:10 PM
hahahahahaha
theresanovak says: Mar 16, 2008. 7:00 PM
Dried beans also work pretty well.
You will want to be careful about getting small holes in the bag of flour.
Flour + Camera = :-(
rupamagic says: Mar 3, 2008. 6:32 PM
Perhaps if you posted this as "a cheap and easy DIY camera support", rather than a tri-pod, which technically this is not at all. I don't want to discourage you from posting, just trying to be helpful. Keep working on it!
tomonto says: Jul 13, 2007. 2:14 PM
this works the sameas putting somethingbehind it. and besides what happens when you dont have a table to set it on!!! you get pictures of your feet. stop posting worthless stuff
scottra says: Jul 7, 2007. 2:44 PM
I'm all for doing it yourself when it makes sense, but there is a much better, smaller, lighter and more practical alternative on the market (dealextreme.com for a $2.39 metal folding tripod (including shipping).
ichipoodle says: Jul 5, 2007. 11:50 AM
well, what if you were to use contour molding gel, or some of that floam stuff, or better yet: silly putty. i dunno, just stuff from the mind of ichipoodle
Kiteman says: Jul 4, 2007. 12:18 PM
A nice version of a commercial product, but you need to be clearer with the list of materials required. If you use sand instead of flour, you won't have the worry of it getting damp & rotting, plus you could plumb one of those winesaver pumps into the bag - set the camera in place, then suck out all the air and the tripod (bagpod?) is set in place until you let the air back on.
LasVegas says: Jul 4, 2007. 11:29 AM
Why was this unpublished and republished? To remove the comments?
Mfmalive (author) in reply to LasVegasJul 4, 2007. 11:42 AM
of course not,infact I dont realy care about the comments I get..its because of some other problem..
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
