DIY Tutorial - How to Make 3D Geometry Globular 925 Sterling Silver Earrings With Pearl
Published
Introduction: DIY Tutorial - How to Make 3D Geometry Globular 925 Sterling Silver Earrings With Pearl
About: HappyJewelrySupplies exclusively making your jewelry supplies and affordable customizations!
Tools and Materials:
  • Sterling silver
  • Marker Pen
  • water
  • hammer
  • Scissors
  • Lighter
  • Pearl
Step 1: Design and Measuring
Pick a piece of silver and measure the length we need. Use marker to mark on the silver. Next step we will need 4 silver pieces of the same length.
Step 2: Cut
According to the lines of the silver, we will use scissors to trim off 4 silver pieces.
Step 3: Trim and Polished
Polish the 4 silver pieces of the former step. Adjust the length and polish the incision to make it smooth.
Step 4: Welding & Modeling
Pick one of the silver pieces and make both of its ends into round shape. Hold them onto the table and weld up with heat. The other 3 silver pieces will be processed the same way.
Step 5: Cool Off
Cool off the 4 heated silver circles. Normally we would use cold water to soak it and cool it off and avoid getting hurt.
Step 6: Hitting Molding
Put the 4 silver circles into the model and we will use soft hammer to hammer out their shapes.
Step 7: Combination
Match up the 4 silver circles with each two as the image shows to make a globular shape.
Step 8: Welding & Modeling
Add welding powder onto the junction surface of the two silver circles and weld up by heat.
Step 9: Cool Off
Now the circles are welded up and we get 2 silver balls. Use cold water to cool them off.
Step 10: Drilling
As the image shows, we will drill a hole on the top of the silver ball.
Step 11: Measuring & Cut
After drilling the 2 silver balls, we will measure the length we need of the silver wire and trim off the silver wire we need.
Step 12: Welding
The silver wire of the former step will be put through the hole of the silver balls. After that we will add in welding powder and weld up the wire with the ball.
Step 13: Clean & Polishing
The welded silver balls will be put into de oxidization solution and be soaked for 20 minutes. This soaking will help clean off the welding dirt. Next, we take the stuffs into the polishing machine and polish them.
Step 14: Riveting
The pearl will be riveted into the silver ball as the image shows and now we will bend the silver wire outside the silver ball to make it as a earrings’ hook.
Step 15: Complete!
This silver-peasecod is very suitable for the production of earrings, necklaces and pendants. We could make adjustments to the jewelries we choose according to our own needs.
It's a DIY Tutorial for Making 3D Geometry Globular 925 Sterling Silver Earrings With Pearl! Hope you will like it!
Follow us on Instagram or Facebook, you can know more details about us!
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
