DIY Tutorial - How to Make Enamel Sterling Silver Pendant Earrings
Published
Introduction: DIY Tutorial - How to Make Enamel Sterling Silver Pendant Earrings
About: HappyJewelrySupplies exclusively making your jewelry supplies and affordable customizations!
Tools and Materials:
Sterling silver, Water, Hammer, Texture hammer, Scissors, Lighter, Saponification solution, Enamel powder, Kiln – heating, Tweezers, Enamel sieve, Earring accessories
Step 1: Design& Trimming
Draw a mark on the silver piece, and clip the marking line along the silver piece with the scissors.
Step 2: Trimming the Second Silver Piece
According to the size of the silver trimmed in the previous step, draw a mark(a little bigger than first silver piece) on the silver piece, and clip the marking line along the silver piece with the scissors.
Step 3: Softening
Heat the silver piece to soften it and cool it with cold water to prevent burns.
Step 4: Textures Making
Choose the texture hammer you want, hammer on the silver piece to leave the beautiful textures.
Step 5: Textures Making
Step 6: Drilling &Edges Polishing
At the top of the silver piece (total 4pieces), a small hole will be drilled with a hammer drill. Then we use the scissors to trim the silver piece, because the cutting position is relatively sharp and we will use tools to make it smooth.
Step 7: Oxidization and Blacking
Heat up the liquid soap and boil the silver pendant inside the liquid soap till it is blackened. Then we will take the silver pendant out of the liquid soap and use sandpaper to process polishing.
Step 8: Making Enamel Earrings
Put the brass piece on the tweezers and then put some enamel powder into the powder sieve. The powder sieve will be above the brass and we will slightly pour out the powder to make sure the enamel powder is evenly fallen onto the brass.
Step 9: Baked
Baking: Put the brass piece onto the baking rack and then slightly put it into the oven. The temperature will be set as 200℃ and bake it for 1 minutes.
Step 10: Combination
Assemble the earring hook and silver earring pendant.
Step 11: Completed!!
In this video, making a pair enamel Sterling Silver Pendant Earrings. Hope you would like it!
Facebook: HappyJewelrySupplies
Instagram: HappyJewelrySupplies
Our Website: www.happyjewelrysupplies.com
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    2 Comments
    200 C in the kiln?
    Enamel won't fire. You need 700 - 800 C for that.
    Very pretty,but what about counter enamel(enamel on the back side of your disks)? Won't the front enamel flake or chip off over time without it?
