DIY USB Dynamo Charger and AA Battery Charger.
317
10
Published
Introduction: DIY USB Dynamo Charger and AA Battery Charger.
About: I own and run kLite.com.au, I make dynamo lights and live to ride and see different places....
DIY USB charger using AA batteries....
Its a very simple unit....Dynamo goes via a rectifier and charges up the AA 6 cell (7.2v) NIMH pack (marked DC in pic)
AA battery's make the hub lock to use charging voltage of battery...without a booster cap the have a max charge rate of 500mA from hub
For ease of use, I bought a 5v regulator...it outputs 5v @ max 600mA...you can run 2 of them if needed.
http://www.pololu.com/product/2107
when you flick the switch, the battery stops charging and pushes it power to run the 5v reg (for USB output)
I run a little voltage readout to tell me where the voltage is at...
http://www.hobbyking.com/hobbyking/store/__7224__Hobby_King_Battery_Monitor_2S_EU_warehouse_.html
there is a buzzer on board but I remove that, so it just the LED that let me know the voltage for when they are charged...
7.2v battery pack will reach its empty point, just as the 5v REG falls OUT of regulation and turns OFF, thus stopping the batteries from being over drained.
you need to keep an eye on the voltage LEDs, for when they are charged...however 4-6hr and they will be done...
AS the AC from the hub can harm electronics, its made to be CHARGE OR RUN....
I have made a few PCBs for others to try...its very easy to do, with only basic soldering needed....
you can also use 4x NI-ZN batterys as the voltage will be very close....
got a few PCB is anyone wants to try it out...;)
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    Hello, and welcome to the Instructables community!
    It's great that you've decided to tell the world about something you've made by publishing an Instructable. We just wanted to let you know that your project still needs a little more work if you want it to be well received on Instructables.
    Projects that don't include certain basic elements tend not to get the attention that they deserve, and so we'd love for you to check out the list below of what makes a successful Instructable.
    Successful projects on Instructables include:
    - clearly written details of a finished project with instructions
    - proper spelling and grammar
    - pictures of the project that you took yourself
    I'll give you another opportunity to make any final changes to your project before we publish it. Once you're all set to go, please republish your project and send me a quick comment letting me know that you've made some changes. I'll give it a quick final check to make sure you're on the right path, and then remove this note.
    Also, we like to feature and reward pro memberships to really well done projects. If you want to see what we look for, check out here!
    Thanks for your submission and we hope to see your project published soon!
