We are going to make DIY RJ45 Cable tester for incredible cheap.As you know cable testers are really expensive insturments and for people who always works with network it is an essential part.
I will try to help you to build one of them with basic electronic ways.
We will use basic components and methods.The components is going to be easly find in electronic stores.
Ok Here we go Have Fun.
Special Thanks For Mrs.Patricia Zugg
And All Cisco Networking Academy Class & My Classmates
Greetings From Alaska To TURKEY
Remove these ads by
Signing UpStep 1What we'll need ? Scheme
---How is it work ?----
Basicaly 2 connectors are directly connected to battery and leds but they are not connected to each other so we will use UTP cable as a bridge of RJ45 connectors.So if any of Leds are not working that means our UTP cable is not working properly on that Leds so we can troubleshoot on our cable.
I will give the list in 2 parts first is equipments and 2nd is components.
-----Equipments------
PunchDown tool
Soldering Iron
Solder
Cutter
Screwdriver
Cable Cutter
-----Components-----
LED's x8
UTP Cat5 Cable (20cm)
9v Battery
9v Battery Clip
Wall Mount Box
Cat5 RJ45 Female Jack x2
Resistor 220ohm
Female RJ45 Mount Plate
So now we good to go Lets Begin...
I added some complexity, but hopefully some utility and capacity as well.
My final product was a tester that can test individual lines, can also test when only one end of the cable can be brought to the tester (or tester to it), and can identify if the cable under test is a standard or a cross over cable.
Ending project cost is about $30 so not as inexpensive, but does what the commercial tester I found for $50 does. Like yours, it doesn't do signal quality, for that commercial testers charge about $100. I found it better built (solid) and at least a lot more fun than the cheap (my opinion junk) $15-$20 testers on the market.
check it out at http://www.instructables.com/id/Network-Cable-Tester-CAT56/
Thanks again to energytr for the inspiration.
Remember the limits of this type of testing. It is for continuity only (tests for open / broken wires in the cabe). It cannot test for shorts (signals that can cross wires because they incorrectly conduct between each other) or for issues of impedence, cross-talk, or other poor signal quality that can effect network performance.
I'm not knocking the instructable (its nicely made), but just letting those who may be interested in testers that there are cheaper options.
I also have a 4 pair tester that indicates at a pair level 1,2 3,6 4,5 7,8
Then there is the Fluke, this will show me the entire wire map and where the break in the wire is at in the cable. (with in a foot)
Nicely done though for some one that just needs to make sure the patch cord is good.
Great adition! Brilliant Project!!!!
But, I did mainly want to comment that the idea for the case in BRILLIANT! :-D
I wish I had built mine this way, and it has inspired me to think about other projects that might be built this way (cheaply).
Thanks for sharing!!!
The build was quick and easy. I ended up adding labels to each LED to differentiate the pin connections.
Thanks for the Instructable
thank you for these instructions.
But - important! - you got the resistor value wrong!
The value is stated as "220 K", but you most probably meant "220 Ohms".
If we assume a standard yellow LED with a max. allowable current of 30mA, I would calculate the resistor value for the worst case (only one LED works and carries the whole current) as:
9V - 2V / 0,03A = 233 Ohms (220 Ohms would most probably be OK in this case, although slightly over absolute max. ratings).
If you are testing an ethernet cable probably you have a pc nearby; it can be an idea. :)
I think a sp8t rotary switch would be a great addition to the power input side. it wouldn't take that much longer to test, but it would show more of what's going on. I'll have to try this.
This method requires both ends of the cable to come together to connect to two RJ45s in the faceplate. But there are times when you can't bring both ends together (like when the cable is coming from outside your house to inside your house).
I would rather use a separate (passive) RJ45 that can be attached to one end of the cable (like outside at an antenna). The passive RJ45 would connect each wire to its return wire to check continuity at the active RJ45 tester end.
*We are done with first connector.
REMINDER : You will need the same thing 2 times so to other connector you may continue the ways again.
so please before punish read whole passage :)
Sincereley,
www.focalprice.com/CN034S/RJ45_RJ11_Network_Cable_Tester_Leather_Bag_GP_9V_1604S_6F22_Super_Cell.html
i have a few questions.
can you give the specs of your build.
Mostly the Rated value of the LED (Each)
Rated Value of the Resistor.
Great Build by the Way.
AWESOME.
