3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Ethernet RJ-45 UTP Cable Tester UltraCheap (Wall Mountable)
Step 2Lets Punch Some Cable !!!
  • last photo ←
Ok here we go;
* First step is cutting the UTP cable from middle.Like 10 cm is going to be Ok.
* When you cut the Cable from the middle take one of em and cut the covers like 2-3 cm from each side.
* Now you will see the cables will be together you need to seperate them
* You do not need to cut the heads of the cables punch down tool will do that job for us.
* Go ahead and take the cover of the RJ45 Female connector
* As you can see there is colors which indicates the proper location of the cables
* Omg same colors with cables which we cut before :)
* Now locate them in proper location you may want to use screwdriver to keep them harder because they always try to go off
* In that part you will punch some cable This part is the most important and the may be only risky part of our project.The biggest fault in the punch down tool usage is cutter site.Punch down tools mouth has 2 sides 1 of them should be Cutter im sure your tool will indicate clearly too.What we are going to do is we will locate our punch down upon the cable but be sure
****CUTTER SIDE MUST LOOK OUTSIDE****
in order not to cut connection between cable and connector.When you all done be sure there is no cable/s hanging sideways of the connector.If there is some cut them manually
*We are done with first connector.
   REMINDER : You will need the same thing 2 times so to other connector you may continue the ways again.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:energytr
