Step 3Make some soldering
* First of all we need to cut the tips of the cables of our connector which we finished.
*When you cut the tips be sure all in the same lenght because what we want to do is we will connect them each other.
*As i said connect 8 cables to each other and check they all touching anycable.
*Now take your soldering iron and solder the resistor to 8 cables which we connected.
*When your job is done take your 9v Battery clip and solder the positive(+) side to end of the resistor.Dont worry about the negative(-) side because we will use it later.
Add Comment
