3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Ethernet RJ-45 UTP Cable Tester UltraCheap (Wall Mountable)
Step 5Place The LEDs to Plate
   Now we will place our LEDs to holes which we drilled at 4th step.I used green and red LEDs and i placed them as 1 green 1 red but its your call.Only important part of that step is just be sure negative(-) legs of the LEDs should be the same way inside or outside.They all needs to be paralel to each other.(Check images you will understand what i am sayin')
2 comments
Nov 19, 2009. 8:23 AMlaurentio86 says:
 Good job, but i'm not a battery-friend so why don't build anoter version powerd by an USB connector?
If you are testing an ethernet cable probably you have a pc nearby; it can be an idea. :)
Nov 11, 2009. 9:24 AMLrodriguezny says:
i have a few questions.
can you give the specs of your build.
Mostly the Rated value of the LED (Each)
Rated Value of the Resistor.
Great Build by the Way.
AWESOME.
Nov 13, 2009. 1:14 PMcyrozap says:
What about the voltage of the LEDs?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:energytr
