Step 6Soldering The LEDs and All connections together
***When you finished to placing the LEDs what you want to do is stretching the negative (-) legs of the LEDs to each other but in order.Like in the pictures just patch them to lower another LED.And After you finished you must have only 1 enterance for negative legs.Solder all of em together.
Semi Step 2
****Take your RJ45 connection which without resistor and battery clip.And take the whole cover from on it.
*Take the tips of the cables
*Place the connector to the hole on the Plate
*And In order solder them to positive leg of the LED which you want to pick.But be sure you did in order. For example " Top left LED indicates BlueWhite on UTP cable" with that way you can test your RJ45 cables which cable is not working or working properly.
Semi Step 3
****Take your first RJ45 connector which with resistor and battery clip . As you remember we left negative leg of battery clip free.So now we will solder it to shared negative leg of the LEDs thats why we connected them each other.Now you can easly solder negatives together.
*Place the RJ45 To other hole on the plate.
Add Comment
