3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Vertical Photos Tripod
I allways wanted to take pictures of my stuff just like in the movies, with a vertical tripod. This is a very simple DIY project that can be acomplished with other materials, but I used what I had available from an older project.
Step 1Materials
Materials
Work table (with separation)
Acrylic
Sony Cybershot DSC-P200
Four screws/nuts
BOSCH Cordless Drill/Driver
5mm Drill
5 comments
Sep 4, 2010. 6:10 AMNostalgic Guy says:
Excellent idea. I have just found a use for an old digital camera I have had hanging around & another possible adaptation for you idea incorporating the cupboards above my packet handkerchief sized bench.
Sep 25, 2009. 3:32 PMiectyx3c says:
What a great use for a portable workbench. Very clever!
Sep 18, 2007. 12:15 PMmr.bologna says:
Wait...so you created a bracket to set a camera on so you can take pictures directly below the camera, but an adjustable table-vice is required and the objects to be photographed must be placed under the table? If I may elaborate on killerjackalope's suggestion of building a base - instead of building a base, why not extend the acrylic sheet length-wise, tap another hole, and attach it to a tripod? Although the camera would not be directly over the center of gravity of the tripod, the model of camera used in this instructable wouldn't have enough weight to topple a tripod. The additional benefit of a tripod is portability. You're not confined to taking pictures where your work table is. From there, you could easily adapt the bracket for use on a long pole to take pictures from higher up, but this would require a camera remote or use of the camera's built-in picture timer function.
Sep 16, 2007. 1:34 AMlemonie says:
It would've been good to see the camera in there, but if that's the only camera you've got... L
Sep 15, 2007. 6:52 PMkillerjackalope says:
bah marlboro lights! those should be the reds way nicer in IMO nice trick though but instead of using the workmate table try buildin a base to hold the acrylice then having the legs set out far enough that on the widest angle they're just out of view, alloing for optimum photo-age....
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:zextron
