Please make sure to vote for this piece in the Woodworking Challenge!!
You can skip to the last step where I have the video of this build if you would rather watch it.
Parts:
4" x 3/4" planks of ceder (the quantity will depend on the size table you want to build)
2' x 4' 3/4" plyboard for the top
4' x 8' sheet thin panel for shelf bottoms
4 drawer knobs
4 table legs
Tools:
Wood Glue
Nails
Wood Screws
Measuring Tape
Router Saw
Miter or Table Saw
4 - L Brackets
Hammer
Screw Driver
Stain
Paint
Brushes
Step 1: Measure and Cutting
The sides will be 2 of the 4" x 3/4" board stacked on top of each other. I cut small strips out of wood to mount on the inside of the boards to secure them in place.
The top will overhang the sides by 1" so measure and cut this accordingly.
Step 2: Mount the Legs and the Top
Use scrap pieces of wood and mount them to the legs on the inside corners, and then mount the side boards to these. This will connect the back and both sides to all 4 legs. Run a bead of glue along the top side of the legs and sides and attach the top using 4 angle brackets in each corner.
Step 3: Drawers
Now measure and cut the sides for the drawers and route grooves along the bottoms to mount the bottom panel. Then cut the bottom out of the paneling, take into account the larger size to fit into the grooves cut into the sides. Fasten the back and two sides together using wood glue and nails, slide in the bottom piece and the attach the front in the same manner.
Step 4: Final Assembly
After everything is to the size that you need, route all the edges on the top and each drawer front. This is for aesthetics, so the shape is up to you.
Now mount the knobs by drilling holes through the front drawer plates and running the screws through the back into the knob.
Step 5: Sanding and Staining
Apply several coats of the base stain of your choice. After that dries apply a thin coat of black paint. This will allow the table to have a more worn look when the top coat is sanded down.
When the black dries, lightly sand the entire piece to allow the stain to show through in some places.
Now apply a coat of your top paint. I am using eggshell white latex. Allow that to dry and now lightly sand the entire piece to allow the black to show through, and then sand the edges and places that would receive the most wear to achieve the used worn look.
Step 6: Finish
Place the piece in your favorite shot, place some items on it and around it and enjoy!
Thank you.
Video of the build:
Visit Our Store »
Go Pro Today »
I'll vote now :)
