3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Vinyl Wall Art
Step 12Final Thoughts
Final Thoughts
Here is the full wrap around set of images. My room isn't large enough to stand back and get a panoramic shot or even minimize distortion to stitch a set together, so here are simply the three images, in order.
I did this project two weeks ago, and I noticed a few small edges rolled up from the wall. I promptly card-scraped them back down, and they seem to stay down well. Update: 11/2009 (16 months later): after this first week of scraping down the corners once it settled in to place, I didn't need to do anything to maintain the wall vinyl for the following 16 months it was on the wall. Zero maintenance!
This project turned out really well, and I hope it inspires you to make something neat :)
27 comments
Jun 25, 2009. 10:27 AMrasidanks says:
great iinstructable! below my pics
Jan 24, 2012. 12:02 PMquinncan says:
This is awesome! I am renting a room with all wood walls, but it's like plastic wood or something because it's so difficult to hammer a nail in and hang my paintings up. I've been trying to think of an alternative way to "dress up" my walls without creating any damage & THIS.IS.PERFECT! Thank you for sharing! [:
Dec 12, 2010. 11:26 PMivanadrian says:
thnx for this it looks awesome~
im planing to do this with a stronger more industrial viynl (like the one used on car decals)
to do this
awesome instructible keep it up :3
May 16, 2010. 8:25 AMchihuahualover112 says:
 Thanks so much for the step-by-step process of how to do this! i have a newly painted wall with NOTHING on it! it's been that way for so long and i have had no idea about what to put up!! i have several ideas of things to put on my wall...like different kinds/designs of musical notes being played out of the corner...or these weird prism-looking things that i keep on finding myself doodling...i'll post my pictures prolly over the summer when i can work on it! thanks(:
Apr 24, 2010. 8:05 PMrhangatoby says:
you do not understand the level of awesome this is making me encounter
Feb 7, 2010. 9:51 AMravijojla says:
This looks great! Thanks for the nice idea :)
Dec 15, 2009. 8:21 AMazaana says:
wow very good, i wish i had seen this before since ithink it has worked better than what i did. i drew a styleised curving tree on my wall in pencile then painted over worked well but i think this metohd would work better and give a better finish. btw this wall is in a place where it dosent matter about how permerment it is.
Jun 30, 2009. 5:50 AMJjette says:
wow! swirlly-swirl!!! cute!
May 28, 2009. 7:11 PMht2o says:
u should do in a differnt room a full art work like take differnt colors and put them on top of eachother to do a full drawing like art that would look awesome
Apr 25, 2009. 11:13 PMshoshanamarie says:
This is absolute genius. I like to do large chalk drawings on my walls but my landlords always get so upset.....this is so much more rental friendly! I can't wait to use some of my own designs. Thank you so much for sharing.
May 28, 2009. 7:08 PMht2o says:
lol my land lord is my mom (i live with her wat do u exxpect im 13) lol
May 9, 2009. 4:51 PMstamm says:
This was a great idea. Im glade you put this up. I think I will try this with tribal dragons.
Apr 14, 2009. 9:19 PMromojohnny says:
This is really sweet. I like the way it looks. I was planning to do this kind of design but instead decided to get brown and green contact paper and do palm trees in the corners of my room and bamboo in the space between the corners of the room. This was a really creative idea thanks a lot!!
Apr 12, 2009. 8:28 AMTheTrustedOne says:
Absolutely awesome, now I have to finish the CNC machine as I cant cut a straight line to save my life :)
Apr 7, 2009. 4:34 AMGina65 says:
Looks really great and unique!! (I have not seen this before!) Thank you for sharing. :-D
Mar 29, 2009. 9:50 PMRedesign Diva says:
Excellent job!
Mar 30, 2009. 3:34 PMsundaymorning says:
A solution to those of you having trouble finding contact paper in your desired color: I wanted to decorate a section of our apartment with a design that incorporated several colors. Instead of hunting for just the right color, I used translucent (and repositionable) contact paper. After I cut the paper into squares large enough to hold pieces of the design, I painted them using acrylic paint. Two to three coats should do the job nicely. Tip: To make sure your painted squares dry flat, place them on a flat surface and place small weights on the corners. Once the paint is dry and the contact paper is sufficiently covered, trace your design onto the back of the contact paper and cut. While this process may take more time than using colored paper, it allows you to choose ANY color combination you desire! Hope this helps!
Feb 28, 2009. 5:08 PMdemonbabi13 says:
*flips out* thats so cool. I have got to try this!
Jan 2, 2009. 11:03 PMgamemasterful says:
Ooohhhh!!! I have some scrap red vinyl! I've been looking for a way to use it up!
Nov 9, 2008. 12:30 AMmaffeo says:
Wow I really like how you came up with all that. A few times when I was bored I'd take a roll of electrical tape and make pretty simple contour drawings. You took it to a whole other level. If you do get the urge to paint your place some day, you could probably paint over the vinyl, then peel it off, then you'll have a more permanent option. I could see myself trying out something like this pretty soon.
Oct 29, 2008. 4:41 AMschwpz says:
Ooooh, awesome project! :D
I just repainted the walls on my bedroom and have been pondering about how to fill up all the new, white space. This way I get to add some wall decor to those boring whites, but without having my husband going kamikaze on me for messing up his newly painted walls! x3
Swirls, soap bubbles, butterflies... the possibilities are endless! Think I'll go and order me some contact paper! :D
Thanks for making this tutorial and graz with an awesome bedroom and living room decor! _
Aug 22, 2008. 6:17 PMSmithington says:
hooray! I've been wanting to do something like this for a while, but never thought to look for an instructable, thanks!
Aug 7, 2008. 8:38 PMcuteychao says:
Great idea! I'm definitely going to try this! Let's see if mine will look as good as yours. ;)
Jun 24, 2008. 6:01 PMbloodniece says:
I use vinyl sign material in my art a lot.You can also cut vinyl directly on glass or plexiglas. Use a spray bottle of water to create a vapor/mist layer between the glass and vinyl, then apply a full sheet of vinyl. Work the air and water bubbles from the center out using s small squeegee. You can then cut your design out and remove the negative areas of the design leaving the positive on the glass. This is a trick auto detailing companies use and so can you . . .
Jun 24, 2008. 6:10 PMbloodniece says:
Example of how I use vinyl:
Vinyl on Plexi
Jun 26, 2008. 11:40 AMhelp.wanted says:
whao thats awesome! question: is the negative area left sticky?
Jun 25, 2008. 2:44 PMbloodniece says:
thanks
Jun 20, 2008. 6:13 PMvinoveritas says:
Beautiful. That Brad is one lucky guy.
Jun 19, 2008. 5:27 AMsalmonsteve says:
But cant you see the overlapping of the various peices on the wall?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
99
Author:britsteiner(Brittany Steiner - Portfolio)
Game interface programmer / art chick / video game geek.
