DIY Wakeboard/Surf Trainer (Indo-Board)
Introduction: DIY Wakeboard/Surf Trainer (Indo-Board)
Hello everyone
In this indestructible i will teach you how to build a wake-board or surf trainer very similar to an indo-board
You will need:
> 5-6 inch PVC pipe about 6 inches longer than the board you will be using on it
>2 bicycle inner tubes
>Old wakeboard, surfboard or skateboard without trucks
>Wakeboard handle ( optional for wakeboarders )
Step 1: Building the Roller
The roller is a pretty key part in making your trainer work
>Take your bicycle inner tubes and chop the valve off
>cut down the centre to produce a flat piece of rubber
>Tape this piece of rubber onto the roller with parcel tape or duck tape
The roller is complete
Take your old board and put it in place
Step 2: That's It ...... Just Ride !
Put the center of your chosen board on the roller and step on with both feet evenly spread. Then rock towards the end of the board that is in the air and you will begin to balance. When you get better 180's, 360's and shuvits are all possible. For the beginner wakeboarders you can use the handle attatched to a tree to get a feeling for the backside rotation and also how to balance on rails.
It also provides a smoother ride if you do it on carpet or an old rug and a flat piece of grass is also very good
Thanks very much and have fun :)
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Paper Contest 2018
      Paper Contest 2018
    Every time that I try this, I wipe out miserably. How long did you have to practice to get good at it?
    When you say you wipe out are you falling forwards or is the roller slipping out or some other thing i didnt say ? It took me about 10 mins but i have been doing wakeboarding for about a year
    Maybe I just need to keep at it. Which would you say is easier a smaller diameter tube or a larger diameter tube.
    A smaller diameter tube is easier and also if you are using a board that curves upwards e.g. wakeboard or skateboard. if you turn it upside down and stand on the base then it will be easier. good luck :)
