3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Wart Removal
DIY Wart Removal
Want to get rid of a wart, but don't want to use harsh salicylic acid or pay for an expensive wart-freezing kit? This instructable will show you how to freeze off your own warts for 1/3 the price.
Step 1Get the supplies
Get the supplies
You're going to need a can of computer duster from your local office supply store. The ingredients in the one I've used is simply tetrafluorethane gas (non-carcinogenic, and non-flammable for the record) compared to the retail wart remover which is dimethyl ether, propane and isobutane.
Also pick up a pack of plastic Qtips.
Duster: USD$7 for a giant can (12oz)
Qtips: $2.50 for 375
vs.
USD$25 for a wart freeze off kit (12 uses total)
38 comments
Jul 23, 2007. 6:54 PMbleachworthy says:
(removed by author or community request)
Jun 7, 2010. 9:55 PMchemistprof says:
Wow, it's amazing how people will simply make stuff up and post it online. Difluorethane is used as a propellant in the above mentioned dustoff because, like all other hydrofluorocarbons, it's chemically inert. Other fluorinated hydrocarbons are also used as refrigerants simply because they are inert, and are liquid over the appropriate temperature and pressure ranges experienced in a refrigeration system. The same goes for teflon, a hydrofluorocarbon made by Dupont and prized for it's resistance to extreme chemical conditions, such as extreme acidity, or exposure to strong oxidizers, let alone it's tendency to not stick to anything (frying pans, etc.). Difluoroethane does not form hydrofluoric acid upon contact with moisture, no matter how extreme the conditions. If it did, it certainly wouldn't make for a very safe consumer product intended for dusting off electronics! If you experience tissue necrosis with the above cryogenic treatment in a location other than your wart, it is because you got the very cold liquid on part of you skin that was not the wart. This is more a cautionary tale for those with poor eye hand coordination. If you can't get the cold liquid to go where it's supposed to, then no cyrogenic home treatment will work for you. You should instead face the music, and go to a dermatologist.
Dec 17, 2011. 12:16 PMKirkH420 says:
@chemistprof You sound very knowledgeable however this I've done this to myself and other people and it does work. Difluorethane is the agent which basically acts as though it were liquid nitro. Sometimes several applications will be needed over a few weeks. Turn can upside down while wearing eye protection and spray onto a q tip. Apply to wart with q tip and hold till it turns white and you'll feel a minor sting. Leave it alone for 3 to 5 days and it will become a scab. You will begin to notice it itches a lot.... you will end up scratching off the scab and the wart is either gone or noticeably smaller. Knowledge is power and can take you anywhere, but I recommend not letting your knowledge close your mind to ideas which don't make sense because of what you know.
Dec 17, 2008. 8:24 PMbrandon borick says:
wart freeser fom the store has difuorethane
Mar 7, 2008. 1:35 PMamz-fx says:
Absolutely not true. Difluoroethane is a common aerosol propellant and stable in contact with water. It is widely used in hair sprays and deodorants, including those which contain water. It is also known as HFC-152a
Jul 24, 2007. 12:17 AMbleachworthy says:
No, not an alarmist. the information I provided was for Dust Off brand name. it is real, I have had it happen to me, it sucks balls.
Dec 9, 2011. 7:23 PMKiwiGran says:
My doctor has had two attempts at freezing off a large wart I've had on my hand for about 18 years. Both these treatments were pure torture and failed.
Two weeks ago I decided to try something new. I purchased a glass (crystal) nail file which I use each morning to file a little more off the wart. It is now level with the skin surface and will soon be gone.
Very easy and painless.
Aug 13, 2011. 8:27 PMjbean3 says:
This could be a possible solution to get rid of a wart but there are several other easier more productive ways. Not only are there many over the counter products available at your local drug store but several common house hold items can also be used as home remedies and work just as well! Check out this website http://www.getridofwartfast.com ive found several helpful things its worth the look!
Aug 22, 2010. 3:09 PMkasaDD says:
My dad is a doctor and he uses this and says it works better because the dust spray gets colder.
May 16, 2009. 1:16 AMmisslarue says:
I haven't tried it yet, but I've read that tea tree oil, or Melaleuca alternifolia oil, is an effective natural remedy. Tea tree oil is a really lovely product from Australia--it tingles and smells kind of like eucalyptus, and I've used as a treatment for cuts and blisters, because it acts as an antimicrobial. Its also the main ingredient in the Derma Remedies product. I'm going to make an experimental paste of garlic and tea tree oil and let you guys know what happens to the annoying wart on my right heel (the place where I always get blisters from sandals).
May 3, 2009. 11:19 PMrob123 says:
Never use dust remover for wart removal, its crazy!!
Derma Remedies have an awesome product for wart removal. Their stuff is natural and really works!
You just apply to the warts and they flake away by themselves and never grow back. Plus no scarring! Great stuff!
Check out their website to order (they have a buy 2 get 1 free special too)
http://www.dermaremedies.com
May 7, 2009. 4:48 PManthony41 says:
Yes! I agree I tried the product from Derma Remedies too. It worked way better than anything else I tried. Mine just kept growing back with cutting them off/freezing. After a short period of time they changed color and fell off. No burning or scarring. Can't even tell where they ever were on my skin. I was skeptical at first, but not a skeptical as trying Dust Off......LOL! Check them out! You won't be sorry you did!
Jun 25, 2008. 1:33 PMYerboogieman says:
will this work on a mole?
Oct 6, 2008. 6:04 PMpickford78 says:
probably not. it will also hurt like hell.
Jul 10, 2008. 7:30 AMMac_Tonight says:
Just don't breathe it in accidentally. This stuff can and will kill you.
Jun 28, 2008. 10:47 AMgarden burger says:
when i saw the picture of the dust remover i just thought "what crazy person would ever try this"
Jun 15, 2008. 7:03 PMavengingwatcher says:
This worked like a charm for me. 3 dollars for it :) Thanks so much for the idea, almost a year later and still healthy and wart free. Saved me over 17 dollars.
Jun 12, 2008. 4:14 PMdrerock says:
it didnt work, dammit
May 14, 2008. 2:47 PMyoitspoe says:
tetrafluorethane is actually flammable under a few certain circumstances and may cause flash fires, but most of the time you're safe
Nov 18, 2006. 8:08 PMaustin says:
so does this work for genital warts? lol, my firends and i used to mess around with each other by sneaking up behind each other and spraying tthem with this stuff, It would hurt like hell, and as long as you didnt do it to long it would not cause permenant damage.
Nov 19, 2006. 2:09 PMCementTruck says:
Hmmm. Genital warts + duct tape underwear/cup/jock strap/G-string.
1)Cheap
2)Disposable (never needs washing)
3)Removes warts
4)Epilates - side effect (removes unwanted hair)
I'll stop here----
I don't see a down side. ;)
Nov 18, 2006. 8:39 PMNonPermissiveEnvironment says:
Duct tape works better. It's been proven.
Nov 17, 2006. 7:42 PMspinach_dip says:
1, 1, 1, 2 Tetrafluorethane (R-134a) has a boiling point of −26.6 °C (−15.9 °F)
Nov 17, 2006. 11:29 PMAndrew546 says:
I fixed the label on your spray can :-p
Nov 17, 2006. 11:51 PMAndrew546 says:
Whoops, I guess using the right picture would be a good idea...
Nov 17, 2006. 7:58 PMcanida says:
Have you tried duct tape? Studies show that it's more effective than freezing for wart removal.
Nov 17, 2006. 11:19 PMAndrew546 says:
Yay, i want to struggle to keep duct tape on my hand for 2 months while my wart slowly dies of old age!!! Haven't you heard? Random pieces of duct tape on you hand for 2 months is the newest, most awesomest fashion statement out there! 2 months, or maybe a week or so, hmm, which should i choose?
Nov 17, 2006. 8:25 PMspinach_dip says:
yea, but the duct tape takes weeks, and it's a pain in the @#$ when the tape must be kept applied to an area that you are always washing, such as your hands
Aug 2, 2008. 4:12 PMmerseyless says:
Duct tape... what cant you do
Nov 17, 2006. 7:38 PMspinach_dip says:
Computer dust-off spray: not intended to diagnose, cure, treat, or prevent any disease
Nov 17, 2006. 6:58 PMTheCheese9921 says:
wo do you think this will work on a corn i have one on my foot
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ccrook
Student at the College of William and Mary in Virginia.
