loading
Step 3: Freezing Part
Invert the can and give a couple of short bursts of freezing liquid until the Qtip is saturated with it (you'll see it splash off). Avoid getting the liquid on you anywhere else than the wart because it can cause frost bite.
Wait about 10 seconds and apply to the wart you wish to remove. It's going to sting, but it's just like getting something liquid nitrogened at the doctor's office
I'm not responsible if you maim yourself somehow doing this. Use common sense.
<p>I just went to the doctor. He took a can of liquid nitrogen that came with a straw. The kit had translucent white mini funnels in it with different sized holes for different sized warts. You can buy liquid nitrogen in a can online. Same with a set of plastic mini funnels. Stick the funnel on the wart. Apply pressure. This isolates the area. Spray on liquid nitrogen for a few seconds. Let it bubble and evaporate for a few secs. Apply again. Then at most a third time. Lift off the funnel. You just freeze dried your wart. Your body thinks the small area got frostbite. If the wart has a raised surface use flat toenail clippers to clip it flat. The skin will turn grayish white in a day (this was on Caucasian completion skin). It is dead skin. It will possibly blister and redden. It may peel or flake off or come off in a clump. Underneath it will be pink and ooze. Once the raw skin is exposed underneath, keep it out in the open and dry. Don't cover it with sweaty plastic bandages. Let it scab up and reheal. Before the dead skin falls off, you can facilitate exfoliation with over the counter wart removal kits. I love the ones with the little skin shaped discs that go right on top of the wart, and you cover it with a round disc shaped band aid. The discs contain salycilic acid which dries out the skin and makes the dead stuff fall off quicker. At night I take off the disc, let it air out and dry. Reapply in am and wear all day long. If you work with your hands, cook food, wash dishes, etc just wear disposable powdered latex gloves to keep it dry. My doc said to use the little discs then after it heals for a while to promote regeneration of that area. If it doesn't work then do the freeze drying again after it heals. Maybe apply liquid nitrogen four or five times if it's deep and aggressive. Doc said warts are caused by a virus that tricks the immune system and hides from it. Freeze drying is man made frostbite he said, and it stimulates the immune system to regenerate tissue and repair the area down at a deep level. For bad deep warts surgery may be needed. This was for a wart on my hand and not a nasty plantar wart like you guys have talked about here.</p>
This stuff works sometimes, but you still have to kill the root deep underneath the skin....here's how www.wartremoval.ca
<p>remove our moles, warts and skin tags safely and naturally within only three days. http://goo.gl/SPxXjB</p>
<p>For DIY wart removal at home, there are certainly safer and more effective alternatives than dust remover.</p><p>Check out the detailed guide below for home wart remedies with demo videos, which also covers the pro and con analysis vs the medical treatment (eg. cryotherapy / laser / TCA) and over the counter solutions, for you to make an educated decision.</p><p>http://howtogetridofwartshome.com/how-to-get-rid-of-warts-guide/</p><p>Hope this helps.</p>
My doctor has had two attempts at freezing off a large wart I've had on my hand for about 18 years. Both these treatments were pure torture and failed. <br><br>Two weeks ago I decided to try something new. I purchased a glass (crystal) nail file which I use each morning to file a little more off the wart. It is now level with the skin surface and will soon be gone.<br><br>Very easy and painless.<br>
Do u think any other nail file would work?
I used wart off over the counter wart remover. It works but it takes forever. You have to apply the stuff daily for us to 15 days and eventualy the skin and wart should peel off. Unfortunately it did not really work because it didn't peel off the whole wart and it grew back. If you really want it to work you have to keep dedicated to daily applications and possibly having to do it again if it doesnt remove all of the wart. Wart Control from ForcesOfNature, anyone tried this? <a href="http://www.forcesofnatureusa.com/Wart-Treatment-s/1819.htm" rel="nofollow">http://www.forcesofnatureusa.com/Wart-Treatment-s/1819.htm</a>
This could be a possible solution to get rid of a wart but there are several other easier more productive ways. Not only are there many over the counter products available at your local drug store but several common house hold items can also be used as home remedies and work just as well! Check out this website http://www.getridofwartfast.com ive found several helpful things its worth the look!
My dad is a doctor and he uses this and says it works better because the dust spray gets colder.
I haven't tried it yet, but I've read that tea tree oil, or Melaleuca alternifolia oil, is an effective natural remedy. Tea tree oil is a really lovely product from Australia--it tingles and smells kind of like eucalyptus, and I've used as a treatment for cuts and blisters, because it acts as an antimicrobial. Its also the main ingredient in the Derma Remedies product. I'm going to make an experimental paste of garlic and tea tree oil and let you guys know what happens to the annoying wart on my right heel (the place where I always get blisters from sandals).
Never use dust remover for wart removal, its crazy!!<br/><br/>Derma Remedies have an awesome product for wart removal. Their stuff is natural and really works! <br/><br/>You just apply to the warts and they flake away by themselves and never grow back. Plus no scarring! Great stuff!<br/> <br/>Check out their website to order (they have a buy 2 get 1 free special too)<br/><a rel="nofollow" href="http://www.dermaremedies.com">http://www.dermaremedies.com</a><br/>
Yes! I agree I tried the product from Derma Remedies too. It worked way better than anything else I tried. Mine just kept growing back with cutting them off/freezing. After a short period of time they changed color and fell off. No burning or scarring. Can't even tell where they ever were on my skin. I was skeptical at first, but not a skeptical as trying Dust Off......LOL! Check them out! You won't be sorry you did!
will this work on a mole?
probably not. it will also hurt like hell.
Have you tried duct tape? <a rel="nofollow" href="http://www.jyi.org/volumes/volume7/issue5/features/demichele.html">Studies show</a> that it's more effective than freezing for wart removal.<br/>
yea, but the duct tape takes weeks, and it's a pain in the @#$ when the tape must be kept applied to an area that you are always washing, such as your hands
Duct tape... what cant you do
Yay, i want to struggle to keep duct tape on my hand for 2 months while my wart slowly dies of old age!!! Haven't you heard? Random pieces of duct tape on you hand for 2 months is the newest, most awesomest fashion statement out there! 2 months, or maybe a week or so, hmm, which should i choose?
Just don't breathe it in accidentally. This stuff can and will kill you.
About This Instructable
267,092views
20favorites
License:
Bio: Student at the College of William and Mary in Virginia.
More by ccrook:DIY Wart Removal
Add instructable to:
