DIY Wine Bottle Tiki Torch
2,402
62
Published
Introduction: DIY Wine Bottle Tiki Torch
Have an outdoor space that could use some help with lighting and ambiance? Is your back porch full of pesky bugs?
This DIY glass bottle torch is inexpensive, easy to make, and will be the focal point of every outdoor space. Not only does it save the planet by using something that would otherwise end up in the waste bin, but it also keeps the buzzing critters out of sight and out of mind.
Keep scrolling and check it out!
Step 1: BE SAFE!
SAFETY!
Since this project involves the use of fuel and fire, make sure you are taking safety precautions into account. This including having a fire extinguisher near at all times and lighting the torch only once you are in an open outdoor space.
Step 2: Gather Materials and Tools
Tiki Torch:
1. ANY glass bottle with 1" diameter neck
2. Bottle of Citronella torch fuel ($10.00)
3. Electrical tape
4. 1/2" x 3/8" copper coupling w/ cap ($2.00)
5. Tiki wick or rope ($4.00)
Mounting Supplies (Optional):
1. 1 x 1" split ring hanger ($2.00)
2. 2 x 3/4" hex nuts ($0.40 each)
3. 1 x 6" metal rod, threaded 3/8" ($1.00)
4. 2 x 10" x 1" screws ($0.35 each)
5. 1 x Ceiling Flange, threaded 3/8" ($1.00)
Tools:
1. Funnel
2. Drill/Screwdriver
Step 3: Assembling the Torch
Wrap the tape around the wide end of the coupling until it fits snugly in the neck of the bottle.
Step 4: Assembling the Torch (cont.)
Thread the wick through the coupling, with about 2" sticking through the smaller end.
Step 5: Assembling the Torch (cont.)
Fill the bottle with the torch fuel -- small pebbles can be added to the bottle to use less fuel. Fill the bottle several inches from the top.
Step 6: Assembling the Torch (cont.)
Put the long end of the wick and the taped half of the coupling into the neck of the bottle. Let the wick absorb the fuel. (~20 minutes)
Step 7: [OPTIONAL] Building the Wall Mount
Screw the top plate connector onto any wooden surface.
Step 8: [OPTIONAL] Building the Wall Mount (cont.)
Thread the two hex nuts onto both ends of the rod.
Step 9: [OPTIONAL] Building the Wall Mount (cont.)
Screw the rod into the center of the top plate connector.
Step 10: [OPTIONAL] Building the Wall Mount (cont.)
Screw the split ring hanger onto the other end of the rod.
Step 11: [OPTIONAL] Building the Wall Mount (cont.)
Open the split ring hanger, insert the wine bottle and refasten the hanger.
Step 12: Light It Up and ENJOY! :)
  • Stick It! Contest
    Stick It! Contest
  • Pets Challenge
    Pets Challenge
2 Comments
I love it. But the hanger has me a little concerned. Those are dissimilar metals and copper is soft. If it should break for any reason (corrosion or bumped) and the bottle broke when it hit the ground, it would splash a lot of oil around. The burning wick would likely ignite it.
