Introduction: DIY Winged Ear Wrap
Picture of DIY Winged Ear Wrap
Using only some wire and pliers, you can whip up an ear wrap in under an hour. My Pin-spiration: http://pinterest.com/pin/530650768563928448/
Step 1: Cut a Piece of Wire...
Picture of Cut a Piece of Wire...
Now hook the piece of wire around the back of your ear and bend it so it fits juuuuust right.
Step 2: Curl
Picture of Curl
Using your pliers, roll in the ends of the wire so that don't poke you... (Cuz ear wraps are not like a Pikachu reluctant to get on a bus ... you can't Poke-em-on)
Step 3: Draw Out Your Game Plan
Picture of Draw Out Your Game Plan
Sketch a to-scale drawing of how you want the wing to look like. Make sure it's tall enough to stick up behind your ear!
Step 4: Anchor
Picture of Anchor
Take your wire (still on the spool/coil) and wrap the end about a third of the way down the ear wire. It's easier if you clamp the ear curve and the long end of the wire with pliers in one hand and use your other hand to wrap the short end.
Snip off the excess short end.
Step 5: Start Shaping...
Picture of Start Shaping...
Put your ear wire up to your drawing and bend the long piece along the shape of the first "wing feather". You'll notice that what you have right now is more like a loop than a curvalicious wing feather.
Step 6: Add Definition
Picture of Add Definition
To make a nice pointy wing feather tip, grab the "wing feather" just a bit off from where you want the crease with pliers. Press the wire so you get a nice 90 degree-ish bend, then roll your plier-hand counter-clockwise a bit to get that hook-y tip. Go around where needed with pliers to curve the wing feather.
Step 7: Moving On
Picture of Moving On
In between wing feathers, anchor your working wire to the ear wire by wrapping the it to the ear wire.
Step 8: Get Spikey
Picture of Get Spikey
The next wing feathers less of a sassy tip and more of a straight-forward corner. To do that, go right up to it and clamp the round bend with your pliers to get a nice crisp corner.
Step 9: Continue!
Picture of Continue!
Make more wing feathers and anchoring your working wire as you go. When you reach the last two baby feathers, make a loose M shape first, then go back in and pinch the middle of the M to get a more defined corner.
 Wrap the working wire around the ear wire a couple times and snip off.
Step 10: Completion (?)
Picture of Completion (?)
You can now try on your new ear wrap!
Now, I could've stopped here, but I didn't like how it looks kind of messy because the wing feathers are sprawling apart....
Step 11: Tie It Up
Picture of Tie It Up
My solution to the "sprawling feathers" problem was to tie them up together. Bring a piece of wire under  two neighboring "wing feather" wires and cross them. Then pull on both ends really hard so the know won't slip.
Step 12: Clip Off
Picture of Clip Off
Snip off the two ends. You might have to clamp the little knot thing you just made with your pliers so that the ends don't poke out. Just kind of nudge the pokey bits in.
Make more of these little knots on the other "wing feathers" that are too spread out.
Step 13: Fly Off!
Picture of Fly Off!
Slip the ear wrap on and enjoy!
Maxodonis made it! (author)2015-10-19
I had a lot of fun with this! I probably should have made the feathers a bit bigger, but I love it, and don't care what others think. I also curved the feathers out for a fun effect. Thanks a million!
craft-n-genius (author)2013-08-04
Oh wow. that is TRULY AMAZING!!!!! I am SO going to make that!!!! thank-you for posting this!!! (I am truly, and I don't mean sort of but I mean REALLY TRULY super-duper going to have to make that like, as soon as I get my wire out!)
mbagnall (author)2013-08-04
Thankyou for this i had a go and come up with some ideas of my own
twdodd (author)2013-07-15
I'm trying this out as a birthday present for a friend. Already dug through my scrap silver and found some sterling wire to work with. Now I just have to find out how to surreptitiously measure her ear.......
Kiteman (author)2013-07-11
That's really nice.
What sort of wire did you use?
Wuffle (author)Kiteman2013-07-12
Well, I don't know what the wire's made of... all it says on the packaging is that it's 22 gauge.
kondzio29 (author)Kiteman2013-07-11
Looks like brass wire ;)
donedirtcheap (author)2013-07-12
Boss. Beautiful. And very well-written too.
How have I never seen this before? I will make one this weekend.
DDC
zeyanimisbah (author)2013-07-12
Awesome ible
mattnielson (author)2013-07-11
Is this natalie brown
Colleen4614 (author)2013-07-11
Sweet
Critter Mel (author)2013-07-11
I have something very similar from my great-grandmother. Her's was set with rhinestones and only over the top and bottom of the ear.
hotstuff5721 (author)2013-07-11
That's so neat I've never seen something like that!
About This Instructable
11,155views
404favorites
License:
More by Wuffle:Fruity cubesGluten-Free Mini QuicheDIY Winged Ear Wrap
Add instructable to:
