DIY: Wire Wrapped Dragonfly
5,478
56
Posted in HomeChristmas
Introduction: DIY: Wire Wrapped Dragonfly
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about...
Once I saw this wire wrapped dragonfly on Pinterest. I can’t wait to make this simple but adorable wire wrapped dragonfly by myself. It's super easy and funny to follow!
Step 1:
1MM Copper Wire
Wood Beads
Pliers set
Step 2: Make Body for the Wire Wrapped Dragonfly
1st, cut off about 50cm 1mm copper wire, bend it in half and pinch the bend with a flat nose pliers;
2nd, wrap the bent wire to form the shape as picture shows, this is the body of the wire wrapped dragonfly.
Step 3: Make Wings for the Wire Wrapped Dragonfly
1st, bend the wire clockwise to form a loop as picture shows, and place the wire under the body wire;
2nd, bend the wire anticlockwise to form a loop as picture shows, and place the wire over the previous wires; now, you’ve got a pair of bottom wings;
3rd, continue to bend the wires to make the other pair of wings in the same method, notice that this pair of wings is bigger than the bottom one.
Step 4: Finish the Wire Wrapped Dragonfly
1st, use the wire to coil the part where all wings join two times;
2nd, retain 3cm wires and cut off the extra wires, slide a wood bead onto both wires as its head;
3rd, coil several turns at ends of both wires, these are the antennas of the wire wrapped dragonfly.
Step 5: Done!
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
