DIY Wood-Grain Laptop Wrap
Introduction: DIY Wood-Grain Laptop Wrap
A simple tutorial for turning your scratched and dented laptop into a fun and unique statement!
Supplies: Wood-Grain Contact paper (found at most dollar stores), x-acto knife, scissors, tracing paper.
So, to start, go ahead and power off your laptop and take out the battery so you're free to work on it without any worries. If you have all sorts of junk on yours, like I had on mine, you can scrape it off and use a little adhesive remover to get it nice and clean again.
Step 1:
Now, unroll your contact paper, and lay your computer on top with the grain going whichever way you want, then cut around it, leaving a large border on all sides (you'll trim it down later).
Now, you can decide what you'd like to do about the logo on your cover. I decided I wanted mine to outline it, so I used a piece of tracing paper to trace the outline, then laid it over the contact paper in the middle, and cut out using a x-acto knife (I used a little piece of tape to keep it in place while I cut it out). You could also just cut a large round window for it and use a bottle cap or anything that's nice and round.
Step 2:
After you cafefully remove the backing, lay it gently on top of your laptop, careful to line-up where your logo cut-out is, and smooth the contact paper out. Then, flip over so the top of your laptop is now on the floor, and begin trimming the edges. I used my straight-edge ruler and "eyed" it the best I could, re-trimming it if I needed to. Then you just fold up around the edges of your laptop.
If you don't have a round edge laptop, or just don't want your cover to "bleed over" you can also just take the measurements of the area that you want to cover and cut it out before you apply it. And if you'd like your corners rounded a scrapbooking photo-round cutter would work perfect!
Step 3:
I also decided to do the inside too since it was pretty beat-up looking as well - I used pretty much the same type of process to do the inside that I used on the outside, tracing the trackpad and cutting it out beforehand to get the right size.
Step 4:
All done!
  • Science of Cooking
    Science of Cooking
  • Trash to Treasure
    Trash to Treasure
  • Paper Contest 2018
    Paper Contest 2018
Could you warm the plastic with a heat gun to make it conform to the shape? I would imagine they do it when vinyl graphics are installed on a car...
I just watched a video in which a laptop was placed in an oven at 60 Degrees as part of it's temperature resistance testing. That should give you an idea of how much heat can be applied if you're doing something vreative with adhesive materials. The Spec for your system will be available online somewhere. Look for Max and Min Operating Temps : )
Great instructions! I used marble contact paper for my macbook skin. Love how mine turned out!!
When I had a wrap on mine, my laptop went through several hard drives... I think the aluminum case is used as part of the cooling system, and during the summer, the wrap put it over the top. Just a word to the wise.
You are absolutely right about that. Half of the reason they switched to the aluminum unibody enclosure was to improve heat dissipation. The entire computer body is now a giant heat sink. If you recall, the earlier, polycarbonate shell Macbooks (I still have mine) had overheating issues because polymer based compounds are generally very insulative...
I have never used that type of contact paper, but without knowing what it is made from I can pretty much guarantee that the "paper" itself, as well as the adhesive, are going to have poor thermal conductivity and will therefore lead to your computer running hotter than it did before. As nice as the idea is (I like the wood grain look) it is not going to be very good for your computer's health:
Decreased heat dissipation ==> Increased operating temperature ==> increased electrical resistivity ==> slower operating speeds, even higher operating temps, and increased risk of component damage.
From what I can tell, this "paper" is a very thin plastic sticker. But the good thing about it is that it only goes on the top (behind the screen) and by the keyboard and trackpad if you so wish. The parts of the computer that get hot don't have to be covered.
Yes, I had my mom get rid of her pretty new plastic Macbook Pro shell for the same reason. She was sad, but it was a good move.
On the other hand, if you have a black or white plastic-shell laptop with a beat-up exterior, this is a good idea to make it look nicer.
Are there any temperature issues with this ?
ASUS done the same thing with their laptops.
Bamboo laptops.. pretty epic
For that paper, do they make any other colors or just wood grain?
