Supplies: Wood-Grain Contact paper (found at most dollar stores), x-acto knife, scissors, tracing paper.
So, to start, go ahead and power off your laptop and take out the battery so you're free to work on it without any worries. If you have all sorts of junk on yours, like I had on mine, you can scrape it off and use a little adhesive remover to get it nice and clean again.
Step 1:
Now, you can decide what you'd like to do about the logo on your cover. I decided I wanted mine to outline it, so I used a piece of tracing paper to trace the outline, then laid it over the contact paper in the middle, and cut out using a x-acto knife (I used a little piece of tape to keep it in place while I cut it out). You could also just cut a large round window for it and use a bottle cap or anything that's nice and round.
Step 2:
If you don't have a round edge laptop, or just don't want your cover to "bleed over" you can also just take the measurements of the area that you want to cover and cut it out before you apply it. And if you'd like your corners rounded a scrapbooking photo-round cutter would work perfect!
Visit Our Store »
Go Pro Today »
http://usa.asus.com/Notebooks/Special_Edition/U2E_Bamboo/#overview
Bamboo laptops.. pretty epic
I have never used that type of contact paper, but without knowing what it is made from I can pretty much guarantee that the "paper" itself, as well as the adhesive, are going to have poor thermal conductivity and will therefore lead to your computer running hotter than it did before. As nice as the idea is (I like the wood grain look) it is not going to be very good for your computer's health:
Decreased heat dissipation ==> Increased operating temperature ==> increased electrical resistivity ==> slower operating speeds, even higher operating temps, and increased risk of component damage.
On the other hand, if you have a black or white plastic-shell laptop with a beat-up exterior, this is a good idea to make it look nicer.
This stuff should be scratch resistant right?
