DIY X Y Axis Tailstock Lathe Homemade Mini Milling Router Wood Slide CNC
893
26
Posted
Introduction: DIY X Y Axis Tailstock Lathe Homemade Mini Milling Router Wood Slide CNC
Materials:
4 pcs Aluminium Alloy 420 mm x 42 mm x 12 mm
1 pcs Aluminium Alloy 290 mm x 42 mm x 12 mm for X
1 pcs Aluminium Alloy 240 mm x 42 mm x 12 mm for Y
1 pcs Aluminium 90 mm x 90 mm x 8 mm
4 pcs FL08 2 Bolt 8mm Bore Self-aligning Flange Ball Bearing
More Homemade mini Milling DIY X Y Z Slide CNC Drill Home Built Lathe Router Machine
1 pcs 340 mm 8D 8mm Lead Screw Dia 8mm ,Lead 2mm, Length 340mm with Copper Nut
1 pcs 280 mm 8D 8mm Lead Screw Dia 8mm ,Lead 2mm, Length 340mm with Copper Nut
2 pcs 12 mm 12 x 300 mm linear shaft 3d printer cylinder linear rail linear shaft axis cnc part
2 pcs 12 mm 12 x 250 mm linear shaft 3d printer cylinder linear rail linear shaft axis cnc part
8 pcs Linear motion ball slide units block bearings SC12UU Bore size 12mm
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
do you any drawings or layout diagrams
