Introduction: ​DIY Y Axis Slide CNC for Homemade Mini Mill Router
DIY Y Axis Slide CNC for Homemade Mini Mill Router by aluminium alloy
Homemade mini Milling DIY X Y Z Slide CNC Drill Home Built Lathe Router Machine
Material:
1 pcs aluminium alloy 300 mm x 150 mm x 12mm for bed
1 pcs aluminium alloy 122 mm x 300 mm x 12mm for X axis
2 Pcs SC20UU 20mm Long Aluminum Linear Motion Ball Bearing Slide Bushing for CNC
4 pcs Linear Motion 20 mm Shaft Support Block Aluminum
2 pcs 220 mm 20mm Shaft Long Hardened Rod Linear Motion Shafts
1 Ballscrew RM1210 12mm 150 mm and bearing
More Good Projects Homemade Nice Work for DIY Handmade here:
About This Instructable
1,280views
24favorites
License:
More by joulethief669:DIY Axi Draw Bot 4xiDraw Robotic Pen AxiDraw Homemade Robot 3D Printer Plotter CNC Laser ArduinoHomemade Laser Engraving Plotter DIY Pen Draw Mini Machine CD RW DVD Drives Mechanism CNC ArduinoHomemade Wood Mini Lathe Collet ER11 Drill DIY Headstock Chuck Spindle Tailstock Slide Mill CNC
Add instructable to:
