loading
Step 5: Hiding the Electronics
Next you will need to spray paint one side of the popsicle sticks you taped together yellow (not the stacks). Use your glue gun to attach the un-painted side of the fake wall to the front sides of the popsicle stick stacks that are already glued in the box. This will cover most of the electronics. You need one more popsicle stick to completely hide the electronics. It will have to be cut down the middle (the long way) making it small enough to cover the little opening above the electronics. Once you have cut it to the right size, you need to spray paint one side of it yellow. Before placing this piece, you need to a very small notch out of it. The cut needs to be right above where the activation switch on the circuit board is. It has to be big enough for a small piece of paper fit through and break the electric connection (like the tab once did). Once again, the pictures in this step illustrate what need to be done.
Can you replace the batteries on the audio? If so, how would I be able to do that?
I love this instructable so much!! Thank you for sharing it.
<p>Clever use of the greeting card. I like this.</p>
I love your Instructable. I'm definitely going to do it and fill it with rupees or a master key or something. How did you manage to get the tacks/nails off? I used the exact same chest for a project and couldn't pry them off. I also just had the idea to use one piece of balsa wood or similar for the fake back.
<p>Thanks bathsheba_everdene! We used some pliers and a flat-head screwdriver to take the tacks out. Also, I think balsa wood would work great for the fake wall in the back.</p>
About This Instructable
31,437views
374favorites
License:
Bio: This is a joint account if you like what we have here check out our separate accounts which are goldlego, dogsrule0909 and creativity123.
More by Golddogs123:Customizable Cup Superhero Card Game DIY Magnetic Dart Board
Add instructable to:
