"DIY" Airsoft Blow Gun
9,772
19
13
Posted
Introduction: "DIY" Airsoft Blow Gun
 Cool, right?
Step 1: Materials
 For this, you are going to need a variety of supplies that can commonly be found around the house; they are:
Tape
Scissors
A lot of paper
Some Time
You will Also need a variety of things you DON'T have around the house; these are:
An airsoft barrel (length isn't too important)
A handle or two (you can be creative here, you could make it out of knex or someting if an airsoft gun's foregrip isn't at hand)
BB's (Any weight, doesn't really matter)
Step 2: Building the Body
Lets get started! The first thing you are going to need is the paper; this 10-25 pile of paper is going to be forming the body of your gun. So what you have to do is stack all this paper up in a neat pile, and roll it into a long, pretty small tube. Be sure not to make the paper tube's hole TOO small, you're going to need slide the barrel inside it! NOTE: The more paper you use for your body, the stronger it's going to be, but also the heavier the gun will be; I used about 25 sheets for my gun. After you're done this, wrap tape around it to prevent the paper form unrolling, you may want a friend to help you with this part. Place the barrel in the hole you've left in the the tube, leaving 1 or 2 inches left of the barrel showing, and tape it so that it wont slide out. Be sure not to tape over the ends of the barrel; for then your gun then will not have the ability to shoot!
Step 3: Attaching the Handle
 For this step, I used an old airsoft gun's detachable fore-grip, which I (very generosly) taped AND glued to close to the back of the body. For this step, all you have got to do is tape your handle to the body, be sure to use a lot of tape; this handle will be carrying the guns entire weight! I used clear tape for the sake of of the gun's looks, but feel free to use duct tape!
                 You are now done the basic model of your gun. If you want to play with it now, go ahead!
Step 4: Loading and Firing
 To load and discharge the gun, place the BB into the barrel, place your mouth on the barrel, and blow (tee-hee)
Step 5: Attachments
 Here's the fun part; If you're a veteran airsofter who just wants bragging rights for constructing this awesome-looking gun, this is your step!
This is where you can buy tactical rails from an airsoft store or remove them from one of your older guns, tape them to your gun, and o wild with attachments!
At one point, I had a sniper scope, a bi-pod, a laser, and a flashlight mounted to my gun. Truthfully, the gun looked completely outrageous, but I thought it was just complete overkill awesomeness.
Step 6: Stats
 I have tested this gun for quite a while now, and here's what i think:
150+ FPS ( I know, it sounds crappy, but remember this is powered by your lungs, not a steel spring)
50-100 ft effective range (depends on how well you know your gun, and your lung strength.)
2-3 pounds
THIS GUN IS NOT FOR SALE... yet
  • Paper Contest 2018
    Paper Contest 2018
  • Sew Warm Contest 2018
13 Comments
I find it hard to believe it only has 150 fps yet still shoots 50-100 feet. but it's still something I'm going to try.
Honestly, there is no possible way this fires at the given stats unless you can blow with the efficiency of some kind of compressed gas... I doubt that the bb will go straight for a foot once it is out of the barrel.
do you need to use an airsoft barrel
That's awesome... but there are a few things I'd fix:
1 an automatic loader. so yo dont always have to reload through the mouth piece
2 a little X over the mouth piece so you dont breath in the epoxy
3 a little "funnel" type thing that's on real blow guns so its not like just breathing through a straw
ha ha ha i like turtles lol ha ha
im sry but why do you have a bi-pod in the back
.......very sry i looked at the pics worng
btw i think this is way over the top^and cool
Dang, this looks nice.
I dont checl this instrubalbe very often... sorry for not replying
