DIY bicycle trailer
DIY bicycle trailer
After building my first bike trailer (using 12" stroller wheels with a homemade 3/8" threaded rod axle with 1/2" pipe spacer, a 1/2" plywood frame bed with a 3/4" steel conduit tow arm hitched to the rear bike basket handle with a folded bike tire secured with a hex head bolt) I wanted to explore some other designes, methods and materials.
The first was a 3/4" horizontal bend steel conduit tow arm with a caster wheel hitch.
For this instructable I wanted to try a different configuration for the swivel caster wheel and to explore the use of weatherproof and good looking PVC conduit for the tow arm. As it turns out PVC is much too flexible. Even when filled with hot melt glue it is not safe, so I abandoned the idea of using PVC beyond testing schedule 40 filled with hot melt glue. I am curently replacing the PVC with 1" steel conduit, painting the bed and adjusting the spokes.
I did not want to use a semi-trailer design but in testing the trailer with a heavy load of 20- 42", 2 by 4's it became apparent that a longer tow arm was needed and a semi-trailer design would necessary for some loads which requires 1" or better steel and not PVC.
To carry a heavy load I used 2 pieces of 1/2" plywood sheet glued together for the bed and a 5/8" firewood cart stub axle with 20" hollow hub wheels. The resulting one inch thick plywood bed is strong enough to double as a frame and the axle, bearings, wheels and tires of the firewood cart are rated for 200 lbs. It can easily carry over 300 lb. and I expect that my intended load of concrete block, cement and lumber will come close or surpass that weight.
Step 1Materials and tools
Materials and tools
  • last photo ←
1. Axle, wheels and tires.
While there are many axle and wheel options I decided to use the ready made firewood cart recently on sale at Harbor Freight for $29.95. The width and strength are right and I had been looking for a 20 inch wheel with a butt or stub axle to build a recumbent tadpole in case this setup did not work out.
I could have used twenty inch bicycle wheels for the trailer if I only planed on loading groceries. The difference with using bicycle wheel axles is that the frame must surround the wheels to support the axle from both sides. There is a certain advantage in building a trailer this way, especially if you are going to be pulling your trailer through narrow passages or close to objects, walls or fences where the wheels can snag or scrape. The enclosing frame surrounds the wheel and doubles as a heavy duty fender. (You can make one of these by following this instructables.)
2. Plywood sheet
I'm using two 31" by 21" pieces of half inch plywood glued with construction adhesive and screwed together with drywall screws. The resulting one inch thick bed means an integrated frame.
3. Steel electrical conduit
Instead of PVC as shown use 1" or 1-1/4" metal conduit. 1" or better steel plumbing supply line pipe is stronger if you avoid threaded fittings and use a bender to make the angles instead.
A single three foot length of conduit is long enough for a short tow arm with enough room to clear a 26" wheel with the pivot point location shown but a five foot length will allow you to carry lumber. A stick of 10' 1" steel conduit costs about $7 and will provide enough length for two or three tow arms.
4. Steel air hose quick connector
The male part is used as a pattern for shaping the end of the carriage bolt. A quarter inch connector will require a three eighths carriage bolt to make the male fitting, while a three eights connector will require a five eighths carriage bolt. You can also add a quarter inch or three eights inch threaded pipe plug.
5. Carriage bolt
This will be used to replace the male part of the quick connector with the size depending on which size connector your get. Get one that is six or seven inches long with only an inch or so of thread. If the rounded head will not slide snuggly inside a one inch piece of PVC pipe then you will have to grind it down.
6. Caster wheel
You can get two inch caster wheels at Wal-Mart for $2.24 (12/1/2007) but the local flea market where I shop sells them for $1.
7. Adapter plate
You can use a three inch by three inch by one eighth inch or thicker piece of steel plate. This plate will be used to make the bike frame to caster wheel base plate adapter. I used a five eighths anchor bolt washer.
8. Machine screws and u-bolts
The dropout eyelets on my bike take a quarter inch, 32 pitch machine screw. You will also need four one quarter inch, 20 pitch hex head bolts that are three quarter inches long and one that is one and one half inches long to replace the caster wheel rivet axle.
The axle and tow arm are attached to the bed using 1/2", 3/4" and 1" u-bolts.
Tools
You will need a drill with a one quarter inch bit, a rotary tool with a metal cutoff wheel, hack saw, hot melt and PVC glue and a one quarter and a three eighths inch wrench. A lathe would be helpful but I used a 1/2" drill to hold and turn the bolt in place of a lathe proper and a rotary tool instead. Don't forget the micrometer. If you use a half inch drill securely mount it on your work bench to spin the carriage bolt for consistent shaping. You will need access to an assortment of other common shop tools such as a bench grinder and a 1" EMT conduit bender.
27 comments
Jun 6, 2010. 6:55 PMducktape.mac says:
how much does it hold and how much did it cost in total?
Jul 3, 2008. 1:01 PMkishida says:
I was taking a closer look at your universal joint and I think you need one more pivot. When you make a left turn, the pivot in the coupler and the pivot in the castor bearings are in the same plane and that's not a problem, but the joint where the castor wheel used to be could bind if you lean to either side, if this joint doesn't easily move to the correct position.
Oct 8, 2009. 11:55 AMhopit says:
Yes, it looks like theres nothing to account for the bicyle leaning (or the trailer leaning do to uneven surfaces).  What if you wanted to lie your bicycle on its side?
Aug 31, 2009. 10:19 AMHuntingWabbits says:
I'm no expert, but isn't having two PVC pipes holding the trailer on either end of the bike more efficient? Having just one puts pressure on said pipe unnecessarily, and may cause it to wear down faster.
Jul 23, 2009. 12:09 AMbradleyporter says:
is this step really necessary? Couldnt you in theory, plug the male connector into the end of your arm and drill screws into it to attach it? Instead of remaking it?
Apr 22, 2008. 2:05 PMenergeej says:
One solution that may fix the PVC issue and eliminate the need to use steel or aluminum is to cover the ends of the PVC and fill the PVC with a sloppy mix of sack crete available for about $3.00 bucks a bag at any home improvement store. Let it set up and you'll have a ultra strong but heavy coupler.
Jun 9, 2009. 12:57 PMepnnf says:
What size PVC did you originally use for the lever arm? Looks like 1-1/2", schedule 40? Would simply using a 2" or 3" work, or do you still recommend using alum conduit?
Jan 2, 2009. 5:50 PMjeremysp1993 says:
how much weight do you think that the hitch itself will pull? because i want to do this same hitch, and it is like the best one that i have found
Feb 5, 2009. 8:24 PMYerboogieman says:
I imagine, JUST THE HITCH, would carry over 120 pounds, although like just like jumping on it or anything, it could easily break off
Aug 5, 2008. 6:55 AMwenzelkid1094 says:
do you think it would be neccesary to maybe attach a bolt to the adapter plate so then in case of mishaps and you turn to hard that the trailer arm does not come in contact with the tire. thanx.and please answer.very interesting idea
Jul 3, 2008. 12:39 PMkishida says:
I really like the use of the coupler & wheel swivel in your universal joint.
May 31, 2008. 4:02 PMGuyj says:
Ever have any issues with the quick disconnect uncoupling during trailering? I cant help but consider the trailer arm getting lodged in the bicycle wheel or turning into a lane of car traffic. That would be catastrophic!
May 27, 2008. 11:25 PMDerin says:
a solution to the arm problem is using a back fork from an old bike...metal frame and weld plus the bolt-in wheels on the side
Apr 22, 2008. 2:01 PMenergeej says:
Bicycle wheels with spokes are less then ideal for a bicycle trailer. If your hauling anything of significant heft, the wheels instead of rolling in a circle they can shuffle and twist and bend the rims. Which happened to me a couple of times. I eventually attached a 1/2" rod to the cart and replaced the wheels with standard 1/2" hub balloon wheel barrel wheels. The outcome was a cart that could carry 300 lbs with ease and rolling resistance was minimal.
Dec 4, 2007. 4:52 PMBrennn10 says:
I love this, nice job!
Dec 4, 2007. 4:31 PMrocknrollskwurl says:
ingeneous mechignizim for the hitch atachment, i love the use of the old swivel caster!
Dec 4, 2007. 3:10 PMGorillazMiko says:
nice instructable! (favorited)
Dec 4, 2007. 8:35 AMBobS says:
A simple trick for pipe bending is to first bend the pattern in a paperclip. It can be very hard to remember how to orient your angle, even if all the measurements are perfect. Actually, sometimes it can be easier to use compression fittings, because mistakes do creep in!! (I usually buy 1.5 x the amount of pipe I need, or use fittings, like I did on my FOUR WHEEL CART
Dec 4, 2007. 8:37 AMBobS says:
Dec 4, 2007. 5:18 AMBobS says:
Good luck with the PVC.... Whenever you find a steel pipe (central heating, conduit), I would strongly suggest to replace the PVC. Over time it becomes more and more brittle... and then you'll be stranded with your cement! I love the caster wheel hitch design!
Dec 4, 2007. 8:07 AMrobgonzo says:
Stuff the conduit with sand before bending will eliminate those kinks. Nice job on this. The hitch is great!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
61
Author:watermelon
I'm an Emu. As a young chick my parents use to feed me watermelon and I loved it so much everyone nick named me, you guessed it, watermelon. Now that I have moved away from home I rarely get to eat an...
more »
