Step 4Remove the rivet axle and caster wheel
This is done using a rotary tool with a cutoff wheel. The cutoff wheel is used to grind the top of the rivet head down without cutting into the caster fork. Once the head is ground down you can knock it out with a pointed object and hammer or pry it out. Be careful not to damage or bend the caster forks.
Add Comment
