3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY bicycle trailer
Step 9Make the trailer hitch male fitting
Mount the bolt in a lathe or in a 1/2" drill you have secured tightly to your bench. (Stop right here and put on your safety goggles, if you have not already done so.)
Using the male quick connector fitting as an "eye balled" and hand micrometered pattern, power up the drill and use the rotary tool to cut the half circle profile recess in the bolt as it is spinning.
I used a micrometer to be sure I did not take too much off the slightly smaller diameter of the bolt end or cut the recess for the ball bearings too shallow or too deep. The replacement bolt needs to slide all the way into the female end of the connector, lock in place and be able to rotate freely while remaining snug - an easy task to accomplish if you take your time, concentrate on what you are doing and go slow. Lots of short soda breaks will help.
Quick connectors from different manufacturers may not have the exact same dimensions, so cut the bolt to fit the same quick connector you plan to use that you also use as the pattern.
1 comment
Jul 23, 2009. 12:09 AMbradleyporter says:
is this step really necessary? Couldnt you in theory, plug the male connector into the end of your arm and drill screws into it to attach it? Instead of remaking it?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
62
Author:watermelon
I'm an Emu. As a young chick my parents use to feed me watermelon and I loved it so much everyone nick named me, you guessed it, watermelon. Now that I have moved away from home I rarely get to eat an...
more »
