Remove these ads by
Signing UpStep 1: Materials Needed
1.) Large peice of ripstop nylon - 3 & 2/3 yards - You can get this at most sewing stores: JoAnns, Michaels, even Walmart (if they have a sewing section).
2.) Sewing machine
3.) Paracord( any type of rope will do, as long as it will hold your weight. I prefer paracord for it's size and weight capacity). The length of the cord will depend on how far apart the trees you hang the hammock from are.
4.) 2 carabeeners or other type of clip, which must be able to hold your weight as well.
A.) I have also seen people make hammocks out of bed sheets( perferrabley large ones)
Visit Our Store »
Go Pro Today »
it has a special weave that stops ripps.
Bought the ripstop nylon at Joanne's on sales and with a coupon! I already had a pile of para cord. Then I recycled a set of webbed boat straps, (The straps no longer worked with my kayak or car.) Wha La.. a very comfortable and secure hammock. I will likely make a couple and give them to brothers and sisters for Christmas. Thank you!
Does any one have any ideas about other synthetics that are available that would serve the same purpose? I think it would be fun to do some stripes!
Again, thank you!
I'm just having a *really* hard time finding the fabric that can work. I've tried all the usual fabric stores but they aren't sure if the fabric can hold the weight.
Any advice anyone?
Great instructable! keep it up!
Good stuff - I'm thinking of 'ibling a rope hammock I saw used on a scout site last year. Bear this in mind though!
http://www.hammockforums.net/forum/showthread.php?t=1672&page=2
1. Thou shall practice and understand your hammock BEFORE going forth to the woods.
-Lest thy spend the first night in a hammock planted firmly upon the ground.
2. Thou shall require Bottom Insulation.
- Hammocks get cold on the bottom in all but the warmest weather.
Using a pad, pod, or underquilt will keep you warm in diverse weather
conditions. Each system has its own unique pros and cons and temp ratings.
3. Thy Hammock shall be protected from the storm.
- You need a tarp to stay dry. Smaller tarps save weight and are good for
light rain with little wind. Larger tarps are required for wind blown rain and
to protect underquilts or pods from getting wet. Under and over covers
provide additional protection and some warmth
4. Thy Hammock shall not fall to certain doom.
- You need to think about your suspension system. There are plenty of options. Knots, ropes, webbing, rings, buckles and other gadgets to provide you with many ways to secure your hammock quickly and safely every time.
5. Thou shall not covet thy neighbor's hammock.
- With so many different types of hammocks on the market, its hard to
know what to get. Comfort is very subjective. Your setup is very personal.
Try many different types if possible before making a purchase. Learn about
the different makes and models and decide what features you need or want.
Don't rule out making your own. It can be done easily and with little required skills.
6. Thou shalt not sabotage thine own hammock.
-Empty your pockets and belt of all sharp objects before entering the hammock.
7. Thou shalt take advantage of the versatility of hanging options a hammock provides.
-Don't settle for a plain flat camping spot when more unique opportunities are available. Make the most of your options by hanging across streams, between boulders, by scenic vistas, etc.
8. Thou shalt practice "leave no Trace" hanging.
-Do not cause damage to any tree or any wilderness area, Thou shalt not spoil it for everyone else.
9. Thou shalt make thy Hammock and Hammock System thy own.
-It's your hammock and hammock system. Don't be afraid to make whatever modifications are necessary to make it more comfortable, easier to set up or take down, etc.
10.Thou shalt choose thy hang with a care for your safety.
-No dead trees, or under "widowmakers" or between speeding trucks, or anywhere you may be harmed.
