DIY Carbon Heated Blanket
62,549
367
92
Posted
Introduction: DIY Carbon Heated Blanket
Very expensive to warm at night the whole apartment when you sleep in a bed. Much better to save money on heating and warm a bed only. So I decided to make a heating blanket.
As the heating element I used the carbon tape. It looks like a thin, soft cloth and not interfere in a bed.
The carbon tape can be sewed, but instead it can be simply glued. Because of this I did it in just 1 hour!
Step 1:
To make the blanket I took 2 pieces of inexpensive fabric
6 feet of flexible wire
20 feet of carbon heater tape 15mm from www.carbonheater.us and now on Amazon
silver conductive wire glue paste, female plug 5.5 mm and iron-on no-sew hem tape. The desired temperature can be determined from the table.
Step 2:
Cut a piece of fabric length of 5 feet (150 cm).
Put carbon tape zigzag. Zigzag shape can be any that you like.
Under the carbon tape to put iron-on hemming web tape. Gently press the carbon tape with an iron that is stuck to the fabric.
Step 3:
Glue the wire to the carbon tape using silver conductive wire glue. Due to the silver glue, contacts will be very thin, very small, will not interfere in a bed. These contacts can be easily and quickly done, and they will be very reliable.
Squeeze between two layers of carbon tape some silver from the syringe, insert the bare wire, squeeze glue place until the glue is completely dry.
Step 4:
Put strips of no-sew hem tape along the entire length of the wire. Fold the edge of the fabric and press iron.
Step 5:
Put contour fabric no-sew hem tape.
Cover with second piece of cloth and gently press the iron over the whole area.
Step 6:
Solder the plug. I connect it to the power supply from my laptop. Work is finished.
Blanket ready:)
Step 7:
Blanket consumes about 40 watts. This power is enough not only for home beds, but also for a sleeping bag in a campaign. Then I connect the blanket to a battery 12 volts.
Blanket is a comfortable shelter, but it can also be put on a mattress under a sheet.
Step 8:
Blanket can be embedded in a duvet cover, but also you can be covered by it alone.
Let my warm save you from danger,
And you'll never cry,
Close your eyes and sleep, my angel,
Sleep, dear, rock-a-bye.
During the day I use it to cover my feet in a chair.
3 People Made This Project!
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
5 Questions
First of all - amazing! I need to make a sweater/upgrade a jacket for my wife. I am a complete newb when it comes to electricity. Would I be able to use a usb battery pack as a source for about 10 meters to sow into arm sleeves, chest and back?? Price is not a problem if there is a solution.
https://www.amazon.com/Anker-PowerCore-Portable-Ultra-Compact-High-speed-Charging-Technology/dp/B0194WDVHI/ref=sr_1_3?ie=UTF8&qid=1517165349&sr=8-3&keywords=usb+battery+pack
at what temperature carbon strip will heat enough to heat up gloves?
The correct question is what power we need and the answer is we need about 5 watts per glove for a moderate cold and about 10 watts for a strong cold. Branded heated gloves usually have about 70C but never reach the maximum and you should make near the same. You can see that idea everywhere, for example a kettler heat water up to 100C only but without water (and thermal switch) it could melt even metal.
Answer form doesn't work correctly, sorry...
Hello Sir! am going to make heated Gloves using Carbon strip. At what temperature carbon strip will heat enough to heat up Glove?
What should you do if you have no access to electricity?
You can use a power bank. You can use the most types of batteries including rc models battery, sla battery from UPS Computer Back Up, etc.
is there any other chargers you can use to charge the blanket?
The most of notebook power adaptors will be perfect.
57 Comments
Hi! I am making an electric blanket as part of a project for school, however the link you have (for the type of flexible wire to use) is dead. Any suggestions as to what would work best?
Ok, thanks so much
How warm does this blanket actually get?? It seems like if it gets to hot, and you use thin fabric then you could burn yourself.....
As you can see on IR photo it is about 41 C. I need a high temperature to use the blanket on a hike. Usually I use it with a dimmer to adjust the temperature and increase the running time.
Oh. Alright. Thanks for clearing that up for me!!
jammychow2017@gmail.com
could you leave me a email so that I can contact you.
our email is sale@carbonheater@us
hi i have send some email to you but is seems doesnt work.
