DIY Carbon Tape Heated Toy Warmer
3,443
35
17
Posted in HomeKids
Introduction: DIY Carbon Tape Heated Toy Warmer
About: DIY carbon heated clothing.
Do your kids love to sleep with a warmer?
It's cold outside, don't you want to heat the whole house, but only children beds?
Let's make a homemade high-tech carbon fiber tape (or Amazon) warmer from any toy animals!
My oldest daughter did it as a gift for the younger in just half a day, I almost didn't help :)
Look how easy it is!
Step 1: How Does This Work
You may have already used the microwave toy warmer or heater with water? If you don't put it under a blanket it cool down faster than an hour. And at first moment they almost hot, and then becoming colder. Nothing is perfect, but we can do better.
We will make it from the most modern and high-tech material - carbon fiber tape. This tape is designed for heated clothes. It looks like an ordinary silk fabric, very thin and soft. The child doesn't feel it under a toy fur.
Unlike other heaters, carbon tape emits in the infrared range so quickly heats the whole body and spends less energy. In our project it runs continuously with a constant temperature of 45 degrees Celsius up to 5 hours. With the power of 50% it works more than 10 hours! RF dimmer allows parents to switch on and off the warmer, adjust the power at any time.
The temperature depends on the battery voltage and the length of the tape. We did about 45 degrees Celsius. It needs 2 feet of 15mm carbon tape only.
Step 2: Shopping List
1. An old toy you would like to be a warmer.
2. 2 feet of 15mm carbon fiber tape and now on Amazon
3. Silver glue.
4. Blinking LED.
5. 18650 batteries.
6. Battery holder with protection.
7. RF dimmer.
8. 2 feet of Iron-on no-sew hem tape.
9. A piece of fabric.
Step 3: Let's Start!
Select a location in which to install the carbon tape. It can be any place you would like. Carbon tape is very soft and can be installed at any place.
We decided to heat only the tummy. Cut out two pieces of fabric to fix the carbon tape heater.
Put iron-on hemming web tape and carbon tape on the fabric and fastened them with pins.
Step 4: Wire Connection
Strip wires and sew them as shown on the photo. Apply a silver glue. Wait 5 minutes and apply the glue again to make contact more reliable. Gently iron the carbon tape. Put on the second piece of fabric and fix the package with iron or just sew it.
Step 5: Don't Be Afraid Teddy. We Love You.
Carefully unpick the seam. Insert the carbon tape. Carefully sew it back.
There's still a little:)
Step 6: The Final Touch
Carefully cut a seam on the back. Pull out the wires from the carbon tape.
We also soldered to the carbon tape a blinking LED that parents saw when warmer is turned on. For LED I burned a small hole on the collar and glued an old button.
In the hole on back my daughter carefully sewed the zipper.
Step 7: Teddy, I Love You Even More Now!
For a child it is a good toy, but we know that it is also a good warmer and my daughter will not be cold at night. Bear is now such warm and pleasant, like a real animal!
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    17 Comments
    Nice project ! Is it possible to improve it by putting some kind of charging port so we don't take the batteries out ? And how does the rf dimmer lets us change the temperature ? Thank you !
    Yes, you can use a power adapter instead of battery. I like to use notebooks adapters they are powerful enough even for a heated blanket but of course you can use many other you find.
    RF dimmer have a wireless remote with buttons 100%, 50%, 25% and + - so you can increase/decrease power as you like. The dimmer used pwm modulation that changes voltage (and power as the result). It designed for led but really perfect for heated clothing. Reliable, powerful, light weight, high current, wide voltage range.
    Thanks a lot for the reply ! So I can charge the batteries in the toy with my notebook adapter ? What should i buy to connect my adapter ?
    Awesome Shenzhen!!! Thanks a lot
    A Cantronic infrared imaging camera:)
    You can see the logo on video.
    Great project! Great idea! :) I want to do this project but I don't know where I can get carbon fiber tape? Are there any alternatives? Or any place I can order it from? I'm from the Philippines by the way.
    Silver glue + protected batteries or protected battery holder = no risk at all. It's low voltage and small current project.
    I guess that is true. I didn't think about it that way. Great project!
    Thank you for this one. I'd never heard of that tape before. That's pretty neat stuff.
    How are you recharging your batteries?
    Thanks for instructable. I'll make this for my kids. How long does the battery/heat last?
    The best batteries last 5 hours at 100% of power (45 Celsius).
