I went online and got Inspired by Amy Cunningham's interlocking design series. I tweaked the idea a little bit, so that it would work for my house and you could do the same thing. It's easy and very customizable because you can chose your own materials and methodology.
I haven't had much time to produce the final piece but I made a desk version that will show you how it looks at a smaller scale.
REFERENCE FOR THE DESIGN: Amy Cunningham's interlocking design series
Remove these ads by
Signing UpStep 1Meassure your wall
Now, it's up to you to decide how many modules you wish to have per row.
For example: If my wall is 6 ft W and I want to have 3 modules maximum per row, I will divide 6ft by 5 = 14.4 inches. The total size of each module will be 14,4 inch x 14,4 inch
Note: Remember that the internal size of the module decreases depending on the thickness of the material you choose. If my modules will be made out of cardboard, this material will be thinner than wood, therefore I need to measure the thickness of it and take it into consideration.
For example: If the size of one module is 14,4 inch x 14,4 inch and I am using a 1 inch thick material, I will have a 12,2 inch module [(14,4)-(2)]
That kind of stuff reminds me of "modern" designs from the 50's and 60's. In my humble opinion I think it is cool to see this instructable. Takes me back to when I made a modular wall unit for my bedroom to display my models, trophies, books and so on. Making it modular I could add to it as my collection grew.
Ivanpope:
Backing up Willrandship's reply (thanks), we designers tend to search for inspirations to create new projects. Since this is not a commercial product nor something I intend to sell or make money out off, it's totally ethic to "re-design" the product. Although I speak of redesigning, I just used her idea as an inspiration to create my own version, and I referenced her while doing so. Instructables is about DIY projects, and I wrote about how to do an interlocking module yourself, in the same way people write about how to do tables, chairs, or even cameras.
You can see the difference from my final desk version and her furniture, it's really different, and I am also suggesting people to modify the design to their own taste. Interlocking modules is a tendency that has been going on for a while, imagine Iamboox2 grandfather did it in his time. Stores like Ikea also do it, so it's not something the designer herself even invented.
Willranship:
Thanks for your support and great suggestions, I believe the support it would provide really depends on the material you choose and how you chose to join it. The width and length of the material is also something important to consider. If you use a rigid piece of wood I am sure it would hold even books. Book you need to nail each corner of each module, so you have a solid structure. If you design the teeth of your pieces to be slightly longer, the piece will have more support on the middle when you interlock it, allowing you to place more weight in that area.
Thank you all for your comments!
cheers!
Denise
Also, it might be a good idea to use a peg system, rather than glue. It would be stronger, and it would be disassemble-able. Desk turns table, turns wall, turns bed, turns chair!
the stool or the coffee table seems easy to remake from mdf, too.
http://www.zemadesigns.com/zema_designs_tables.html
Pegs go into one part, then other. Think knex, the green ones + White joints.
Cheers!
thank see you,
Cheers,
Denise
