DIY Cheap Waterproof LED Lamp
6,390
34
7
Posted in TechnologyLeds
Introduction: DIY Cheap Waterproof LED Lamp
LED lamps are long lasting and very economical. But they are still expensive. Here's how I made a 12V LED lamp, using a LED strip and discarded plastic jar. The lamp costed less than $1 to make and is bright enough to read a book and light up a room!
Step 1: Parts
Here are the parts you need: plastic jar, wooden stick, some wire and LED tape. The LED tape is seld-adhesive, you can buy it on Ebay or any electronics store. In my case I used half a meter V-tac 3528 that costed $0.80
Step 2: Wrap the LED Strip
The LED strip is self-adhesive. Solder the wire to the end of the strip and wrapp the led strip around the wooden stick.
Step 3: Fixing the Stick
Fix the wooden stick to the cap with a screw. Run the wire through a hole on top. You can put some silicone on both places to make it waterproof.
Step 4: Testing the Lamp
Here's how the stick and the finished lamp glows into the dark. It consumes just 12V/135.5 mA! You can use it as 12V camping light attached to the car battery, or at home, with 12V adaptor.
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
    7 Comments
    One of those monster batteries would drive a handful of LEDs almost forever!
    I like the containers for kool aide and country time lemonade for my lamps.
    it would be great if you find one with yellowish touch - this way the light will look more natural.
    You can power those LED strips from a 9v battery, even though they are rated for 12v. They don't light at full magnitude, but they are still bright enough for a use such as this. You can attach a metal battery holder to the inside of the lid, and the srtip lights directly to the 9v battery clip.
    In fact I made later versions with matt white bottles like this one and it works even better - more compact and lighter.
    yes, or maybe one like this
    http://www.vapextech.co.uk/acatalog/High_Power_Model_Control_Batteries.html#a26
    Ooh, nice! I like the spiral pattern in the last step! That would be a pretty cool lamp by itself. Although the plastic jar diffuses the light so it's much less glaring...
    Nice project!
