This website was among the more helpful sites as it provides Jeep's Repair kit instruction. Thanks for a well thought out site, and permission to borrow content.
http://www.denlorstools.com/autoblog/2010/03/jeep-grand-cherokee-dual-zone-blend-door-repair/
This site does a good job of where and how to cut, so I will not re-invent the wheel. I'll show you my solution to the kit from Jeep.
Total Cost of Project:
$1.76 Mending plate ($0.88 x 2)
$3.36 Hinges ($1.18 x 2)
Required Materials / Tools:
4 - 1/8" rivets
1 - Rivet gun
hacksaw or rotary tool (the hacksaw requires more patience than I possess)
Drill
Remove these ads by
Signing UpStep 1Problem...
I decided on a standard 3 inch door hinge as my new pivot point. This stamped steel piece should be more than sufficient to withstand the calibration forces. The door is a reinforcing plate typically used on decks and truss frame construction. These both will be very easy to find at your local home center. The truss plate is found in the pressure treated section. You will need 2 of each to complete both blend door repairs.
comment
Add Comment
Add Comment
