3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY flip minoHD quality underwater case
Flip Mino HD it´s a easy to use camera, with good image quality for it´s small size. In good light conditions it displays a clear sharp footage. I wanted to use this camera to record my scuba diving and fishing, but since i can´t find a case for this camera, only for flip ultraHD and the rated depht of the flip case is only 30feet / 6m, i decided to build a custom case for this camera.  This is the 3rd custom case i build for my photo and video cameras. None of them ever failed, and all of them have gone past 10meters depth.
Step 1Gathering materials and total cost
I´ve used the following materials for this build:
- 15x20cm 3mm thick Acrilic sheet for the main body.
- (2x) 9x14cm 8mm thick Acrilic sheet for the lid and for added thickness of the main body
- Epoxy glue
- Wood mold
- Rubber oRing
- Stainless steel bolts and nuts
- Aluminium parts from old HDD for start stop rubber button and visor protector.
- other parts
Cost in euros.
Acrilic - 3,5 eur
5X rubber gaskets - 4eur
Glue - Already have but a 2 compound seringe like this will cost you 8 eur. you´ll use about 5% of it
Stainless steel bolts and nuts - 3,5eur.
Other parts have to be scavenged so costs may change.
It also helps to have the right tools for machining and threading
In total i didn´t spend more than 15eur in this project
19 comments
May 8, 2011. 7:10 PMrichie_114 says:
Awesome 'Ible!! Well done!! I wonder If I could form that acrylic with my home brew vacuum molder?
May 9, 2011. 2:39 PMrichie_114 says:
Glad you tried it first then. Thanks for responding!
May 25, 2010. 3:52 PMkcls says:
Nice 'ible! I wanted to make one for my digital camera, but it has way more buttons. How could I make it work? The picture of the camera is below. It has a circle button, with a button in the middle. There are four buttons surrounding the circle buttons. On top, there is the button to take a picture surrounded by the zoom knob. The power button is also on top. Thanks!
Nov 3, 2010. 7:46 AMducktape.mac says:
do the bolts scratch the camera?
Nov 3, 2010. 10:01 AMducktape.mac says:
okay, thanks.
Jul 15, 2010. 2:13 PMajmckay says:
Great Instructable!!! It's given me some good ideas, as well as a confidence that a high-quality hard case can be made without having to buy one for $200 USD. One question though, any other ideas on where to find the screw you used for the on/off button? I have a Kodak Zi8 which I want to build an enclosure for. I don't do any diving, but I want to make one which I can use to video my fish tank, and also to protect from dust and impact while I take it on mountain bike rides strapped to my helmet. Most of the other instructables are either too flimsy (plastic bag) or too bulky (pvc etc...) for my purposes so I have been designing a similar enclosure out of acrylic. Mine is slightly different in that I need some weight reductions so I will use 1/8" acrylic (mine won't go so deep) and nylon screws. I will also use a gasket over the entire back using a thick plastic sheet (Intra-veinous drip bag). I'll post my instructable next week.
Jun 15, 2010. 9:09 AMfxkill says:
Would you happen to know the size of the oRing, its the last item I need to start building this awesome case.
May 25, 2010. 3:20 PMJobar007 says:
Is ambient pressure a problem at depth with the button on the back? As in does pressure at depth actuate the button on the back?
Awesome idea by the way. As soon as I saw what you were doing I smacked my forehead saying, "I know how to vacuum-form plastic. Why didn't I think of that!?!"
May 25, 2010. 10:16 AMfruitkid101 says:
Hey great one! I've been molding acrylic to make iPod cases for me and my friends, they all love theirs. I've been doing it since last year. I should start selling these...
May 24, 2010. 8:57 PMmikejs says:
This is awesome - I love the way you've molded the acrylic, and that jig you built for it is pretty genius. Projects like this are what makes Instructables great.
What are the measurements for the block you used? And have you considered shaping the wood block to match the contours of the Mino? It looks like a pretty perfect fit already, but might be able to have it fit even snugger, especially where the lens bevels out slightly.
Also, where did you source your case gasket? Or did you use a gasket compound for it?
Keep it up!
Mike
my DIY blog: mikesenese.com/DOIT
May 24, 2010. 10:35 PMPueo says:
I like it!  Question though, where did you get the O-ring from?  I didn't see it on the parts list.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:tiagoblanquet
