Step 3Threading the wire
Measure out 15 ft (or the halfway point) and mark it. Now starting at the middle point of the crotch, feed the wire all the way up to your halfway mark. Now tie a loose nut or put some tape to keep the other half from passing through. Make your way down the inseam, and then follow the pattern that I drew below. You'll want to finish around the waistband area. This is where we'll attach a connector. Once you finished with the one pant leg. Repeat the process for the other pant leg with the other half of the wire.
This new layout is better as well because it doesn't constrict the legs like the spiral pattern does. It makes it much easier to put the pants on.
Regarding the 9v battery, if you are talking about the ones used in a smoke detector, then no it won't work. Those batteries are used for low current drain applications. If you got a 9v battery pack or some other large capacity battery, then yes it would work.
