3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY homeade nerf airsoft gun
This DIY tells you how to make a airsoft gun out of a nerf gun, darts, tape, scissors, and airsoft BBs!! This is for you if you want to play airsoft but you only have nerf guns or if you want to make you freind a gun!!! This is a awesome mod that leaves bruises on you !!!!
DISCLAIMER: MAKE NO MISTAKE, THIS IS A WEAPON. DO NOT SHOOT AT ANYTHING FRAGIAL OR ANYONE. IF ANY PROBLEM OR DESTRUCTION IS CAUSED BY THIS, I CLAIM NO RESPONSIBILITY...................................................'
***** I MADE THIS FOR MY 8YR OLD BRO! I MADE IT TO NOT SHOOT BBs EXTREMELY FAR !! I MADE IT TO SHOOT IN THE HOUSE SAFELY.... AND ITS ALSO LITTLE BRO SAFE CONSIDERING IT DONT HURT!! I USED THESE MATERIALS BECAUSE THESE ARE ALL I HAD (I DIDNT HAVE A BIC PEN OR ANY OTHER KIND OF PEN THAT A BB COULD FIT IN) !!!
SO STOP GIVING ME JUNK COMMENTS!!!
Step 1WHAT YOU NEED!
WHAT YOU NEED!
You will need a.....
- at least 1 NERF gun
- at least 1 NERF dart or stefans
- scissors
- tape
- Airsoft BBs
131 comments
1-40 of 131next »
Jun 6, 2011. 2:55 PMSonicX 22 says:
i have 2 questions:
1. Can i use a gun like the Nerf Recon CS-6?
2. Do i have to do Step 5 first and then do Step 3?
Jul 31, 2010. 12:43 PMPrestonage says:
I made one that shoots at about 450-550 FPS and I've never seen its max distance. But it can also shoot over 15 BB's in one shot at over 200 FPS.
Apr 13, 2010. 2:19 PMcranberys says:
HOW DO YOU TAKE OUT HE AIR RSRICTOR
Jun 4, 2010. 6:41 AMalex4646 says:
you have to unscrew it.then you just look up : air restrictor removal on instructables/youtube. youll figure it out in notime
Jun 13, 2010. 7:17 AMcranberys says:
thanks\
Apr 18, 2010. 4:07 PMApple_4_life says:
 look it up on instructables, or even youtube
Jun 4, 2010. 6:40 AMalex4646 says:
fragial? i know what you mean but still....
 nice job dude, I'm gonna try it when I get my hands on some BBs.
Jan 9, 2010. 10:16 AMimshanedulong says:
What do you think the velosity/speed (fps) might be on this??
Apr 1, 2010. 9:08 AMbillybenj says:
pretty low, but if you remove the air restrictors it will work a little better, maybe like 150 fps max tho, if you use pens
Mar 9, 2010. 3:21 PMtotjup2 says:
i made one from the same gun but i opened it up and removed all the air restricters and stuff from the front replaced it all with some pvc pipe. i also put a pen tube inside the pipe so the barrel is directly connected to the air chamber. then i added a ton of rubber bands. mine shoots about 150 to 170 feet and goes about 325 fps.
Dec 24, 2008. 7:59 AMIronman97 says:
I made one with the same gun. It goes about 200 fps. Should I post it?
Jan 9, 2010. 10:19 AMimshanedulong says:
YES!!! Please post it.
Me and myy friend want to make one out of a nerf maveric to put in a homemade sand bag nest for our airsoft battlefield.
Mar 20, 2008. 12:35 AMdkillman56 says:
i dont really like it nut its ok
Sep 22, 2009. 3:55 PMdkillman56 says:
but
Jun 8, 2009. 5:06 PMCapt. Kidd says:
ummmmmmmmm... i would not make this, because i have done it before, and does not hurt!!!!
Aug 26, 2009. 1:42 PMnerfkid427 says:
My nerf airsoft gun hurts pretty bad if not modded but if it is modded, it hurts. take a look.
Aug 6, 2009. 1:25 AMRaiden97 says:
if you really want to hurt people then buy those guns that shoot those really small bbs, and its not airsoft!
Nov 20, 2010. 8:00 AMHitman227 says:
You mean an actual bb gun. My .177 cal(4.5mm) draws blood.
Jul 5, 2011. 2:32 PMdontkillpenguins says:
mine can kill a fox w a head shot
Jul 6, 2011. 10:19 AMHitman227 says:
Yeah I don't know about mine, haven't ever shot a fox...
Jul 6, 2011. 11:07 AMCapt. Kidd says:
mhm. why would anyone shoot foxes????? T_T i love foxes.
Dec 11, 2010. 4:14 PMRaiden97 says:
im talking about the ones that shoot metal ones, and theyre smaller than regular 6 mm bb's
Dec 12, 2010. 10:01 AMHitman227 says:
Ummmm........ yeah they dont make 4.5mm (.177 cal) plastic bb's. There metal and are for air rifles.
Dec 12, 2010. 2:16 PMRaiden97 says:
yeah i said "metal ones, and theyre smaller than 6 mm bb's"
Nov 22, 2010. 11:46 AMCapt. Kidd says:
Ive got one. I would know.
Aug 26, 2009. 1:41 PMnerfkid427 says:
this is pretty cool. check out my nerf airsoft gun.
May 23, 2009. 9:12 AMpindalanderz says:
works great. one annoying thing though is that the bb's fall out. I'm working on a solution for that. I'll post back when I figure it out
Jan 28, 2009. 5:34 PMPsychic Master says:
i built one but instead of using that nerf gun i used a nerf N-strike dart tag pistol and i can get it to leave welpts on my bros arm from 90-120ft with extreme accuracy =>
May 17, 2009. 11:28 AMfootbagboi says:
dude i tried it with that same gun and it worked perfectly! thanks for the idea
Apr 28, 2009. 1:08 PMwhiteandnerdy says:
Dude I tried this, and it is awsome! I did it to my Longshot CS6 attachment. You know, the one gun thing that comes with the actual gun.
Apr 13, 2009. 7:37 AMJupitane says:
Why don't you make 6mm soft bbs for your little brother. Safety first! =)
Jan 23, 2009. 1:45 AMkenexinator says:
<a rel="nofollow" href="http://www.instructables.com/id/Air_blasters_Double_shot_airsoft_hack/">Here it IS!</a>Here it IS!<br/>
Jan 22, 2009. 7:34 PMkenexinator says:
Sorry i meant nerf dart.
Jan 22, 2009. 7:33 PMkenexinator says:
I made a airsoft gun out of my double shot shotugn from airblasters. It shoots pretty well and all you half to do is stick a straw a nerf inside the shell! i'll post instructions later
Jan 17, 2009. 11:38 AMatlantis1 says:
thanx never mind about my comment
Jan 17, 2009. 10:53 AMatlantis1 says:
mine doesnt even shoot
Jan 8, 2009. 6:27 PMemuostrich says:
Just to add details... Before reading this I did this before...(this shows I have a brain)...so I am "experienced" You might want to be more "clear" about stuff like including that YOU NEED TO USE A RAMROD TO RAM THE BB IN ABOUT 1-1.2 INCHES!!!! THIS DRAMATICALLY(kinda) INCREASES RANGE!!!! Yeah, and I used .24 grams and they shoot far so .2 and .12 should shoot pretty far. You can just use .12 since you don't really need accuracy since it has pretty bad accuracy. And this is supposed to be a "helpful comment" by the way.
Jan 2, 2008. 10:38 PMhi12340 says:
I was wondering how far these things shoot because when I made mine it didn't really shoot far, maybe like 2 feet...maybe it was the tape, or the bb's (.20g-.25g) or the nerf gun, or it was because the bullets were brand new (in your picture they were all squashed up) and that's probably why, because it compressed the air more? So if you have any of these answers please reply to me.
1-40 of 131next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:receiver545
