This is my first instructable. I am going to try and keep it short and simple. Hope you like it.
I have had a model rocket for many years but recently two of my friends showed me a model rocket that they had made (which was really good) but it made me think that it does not cost much ($5-$30) and i could probably make one to but slightly less good. And that is the reason this instructable was made.
Tools:
the tools are not expensive but buy a dremel (or some thing like it) will give a nicer finish
dremel
hack saw
PVC primer (get the pressure stuff because some part will be under stress)
PVC cement ("same as above")
permanent marker
ruler
Parts:
most if not all things in this rocket can be found lying around the house
X 30 Cm of 25 mm PVC pipe
X 15 Cm of 90 mm PVC pipe
X 12 Cm of 15 mm PVC pipe
X 1 20mm PVC cap
X 1 plastic soft drink bottle
X 5 or so rubber bands
X 1 plastic straw
X 1 C sized motor
X 1 plastic rubbish bag
X 50 cm worth of string
x 1 thing of wadding
Note:
This is only to make the rocket not the launch pad or ignition system.
Both can be bought or made dirt cheap!
Remove these ads by
Signing UpStep 1The body
Cut the 25mm pipe to a length of 30cm, and make X4 12 cm, this is where the fins and motor will fit.
it takes a 18mm C6-7, 18mm,
but it has a piece of cut 15mm, because that is the size that the pipe comes in and it also provides a good fit for the motor if you cut it right.
i will vote for ur cd cube
any way of helping out? (they will send it any were in America even if it my house)
hows life treating u
Nice instructable!
I like the fins- have you tested it and does it spiral well?
ya it spirals
And vote for my instructables in the dead computer contest:
Cd cube lights and the soon to be poor mans cd candle
(are you going to change your photo for the new school photos when we get them )
